When HMC8191 or HMC524ALC3B is used as upconverter, How much power is requiered to drive IF?
There is no number for driving the IF power, the maximum power for HMC8191 for example is 24dBm. From the data sheet you can check the conversion loss and the P1dB and based on output system requirement you cab calculate the IF input power.
Thank you
