eliminating the hmc507 fo/2 harmonics
How i can properly terminate the pins which oscillates at the frequency fo/2 so that unwanted spurs will not occur?
    on Jul 31, 2017 4:17 PM
    Hi there,
    The fundamental feedthrough (or 1/2 harmonic) that you see is on the RFout port is due to the topology of the device. If you don't need the RFout / 2 port (fundamental freq) simply install an appropriately sized capacitor for the frequency you're working with and a shunt 50 ohm resistor. Otherwise, filtering is the only means of suppressing it.
    Marty
