ADF4108 :: 20 MHz sinewave as REF input?
Hi there,
I am involved in a new design and we decided to use ADF4108 as PLL frequency syntetizer.
My question is about conecting a pure sinewave signal to the REFin input, I took a look to the ADF4108 evaluation board and it offers the possiblity to conect three different clock options (TCXO...)  or use the external input but we do not know if it is possible to input a sinewave from a signal generator or we need to use a sinewave to LVCMOS converter such as the LTC6957-3 from Linear Technologies (If valid).
Any help would be appreciated.
    Javier.
    on Nov 28, 2017 4:51 PM
    Hey Javier,
    Yes you can use a pure sine reference frequency but of course as the reference stage is a digital circuit, the counter will operate better with a sharper clocking edge (I.e. a better slew rate).
    In other words, the phase noise performance of the PLL may be reduced when using a sine wave ref unless you can ensure the slew rate of the sine wave is good enough. To ensure this is the case you will have to use a higher drive level when using a sine wave than you would normally have to use if you were using a square wave. Typically for a sine wave ref the best phase noise performance occurs closer to upper end of the drive level. Although another caveat of using a sine wave ref is that you should bear in mind you may need to try various power levels particularly if you’re attempting to optimize for spurs
    Alex
  • Hi Alex,
    Thank you very much for your response.
    From the datasheet I got this information:
    So, if I am rigth, you advised me to input a sinewave signal with a level near to VDD volts peak-to-peak.
    In other words when you refer to drive level, are you pointing to REFIN Input Sensitivity parameter?
    Is this OK?
    Thank you again.
    Javier
    on Nov 28, 2017 9:37 PM
    Hey Javier,
    Yep, the REFIN sensitivity is what I'm referring to. I would say it's worth trying a range of reference voltage levels below the max value of 0.8*VDD pk-pk to minimise spurs, but probably your phase noise response will be best when your REFIN pk-pk amplitudeis is close to the 0.8*VDD max value. Note this value is for a 50Ω AC coupled single ended reference, biased at VDD/2
    Hope this helps,
    Alex
  • Hi Alex,
    Good news!! As soon as I receive the components I will give it a try.
    Thanks for your help.
    Javier
  • Hi, I saw this thread and wanted to post my own question for the ADF4108. I'm troubleshooting a board that is using a 10MHz square wave input as the REFIN, AC coupled. On the input side of the cap the square wave is from a CMOS buffer and is perfectly square, 0 to 3.3V. On the PLL side the signal is still perfect square wave, but now the signal is slightly below 0V to slightly below +3.3V. If biased at Vdd/2 should basically be the same waveform correct? The issue we are seeing is 10MHz spurs on our output that is present only on some, but not all our boards, like a few out of a lot of assembled and tested boards. Was wondering if this signal phenomena could explain that?
