Design for 10GHz FMCW
I’m going to design a radar FMCW for 10GHz.
For the transmission side  I think to use the ADF4159  and as VCO the HMC1162.
I would like your suggestion for the receiving side.
What is the best component to use as 10GHz receiver downconverter for FMCW?
In rx side, can I use the component ADF5904 ? .
For  LO input I use the clock coming from the transmission side.
Please , can I have some your opinion about this my idea ?.
Thanks
Regards
Piero
    on Mar 2, 2018 4:53 PM
    Hello Piero,
    The ADF5904 LO / RF range is limited to 24GHz to 25.25GHz ( for 24GHz radar ), what frequency range/ bandwidth do you require?
    regards,
    Brigid.
  • Hello Brigid,
    Thank you very much for your email.
    HMC1162.
    This choice is it valid for you?.
    I would like your suggestion also for the receiving side.
    What is the best Analog Devices component to use as 10GHz receiver
    Clearly for  LO input I use the clock coming from the transmission side.
    Thanks
    Regards
    Piero
    Il 2018-03-02 04:54 Brigid.Duggan ha scritto:
    ENGINEERZONE
    RE: DESIGN FOR 10GHZ FMCW
    reply from Brigid.Duggan  in RF and Microwave - View the full
    discussion
    on Mar 6, 2018 6:34 PM
    Hello Piero,
    Outside of the ADF5904 I don't know of a dedicated rx chip for radar, can you let me know the required signal bandwidth and sweep frequencies. Regards Brigid.
  • Hello Brigid,
    HMC1162.
    With this choice the signal bandwidth and sweep frequencies are those
    contemplated and available from the use of the ADF4159 component.
    In the worst case, you can  consider the limit values envisaged by the
    ADF4159 component.
    Regarding the component ADF5904 if I use for the convertion the 10GHz
    signal coming from the transmission side are you sure that the
    conversion section does not works correctly?
    If it is impossible to use the component ADF5904  can you suggest me the
    best Analog Devices component to use as 10GHz receiver downconverter for
    FMCW?
    Thank you very much for your help
    Best Regards
    Piero
    Il 2018-03-06 06:35 Brigid.Duggan ha scritto:
    ENGINEERZONE
    discussion
  • Hello Brigid,
    Have you  any news about the component to use ,in rx side, as 10GHz
    receiver downconverter for FMCW ?.
    HMC1162.
    I'd like to know if there is in Analog Devices a VCO similar to HMC1162
    but with a dedicated output buffer for 10GHz local oscillator (LO)  to
    use for LO_IN relative to  receiver downconverter.
    Thanks
    Regards
    Piero
    ENGINEERZONE
    discussion
