Hi team,
i'm using the PLL ADF4382 for a new project.
The reference clock of the PLL is a 100 MHz sinewave from Crystek oscillator (CCSS-945X-25-100.000) with an output power of +7 dBm.
The settings applied are as follows:
- LNA On
- FILT REF OFF
- BOOST MODE > 8 dBm
- Doubler On
- charge pump = 11.1 mA
- F_out = 9.8 GHz (integer mode)
I have some doubts regarding the register settings of the register 2F (bit 6 and bit 7). Are corrects?
The register BOOST Mode (bit 7) probably needs to be < 8 dBm.
If these registers are not configured correctly, could they degrade the phase noise?
Can you help me?
Thank you.
Best Regards,
Matteo Ricci
