Hello, I am working on a thermal model in Icepak. What is Theta JC (θjc) for ADF41510? Data sheet only provides JC and JA. Thanks, Mike
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADF41510
Recommended for New Designs
The ADF41510 is an ultra-low noise frequency synthesizer that can
be used to implement local oscillators (LOs) as high as 10 GHz in
the upconversion and...
Datasheet
ADF41510 on Analog.com
I appreciate the confirmation of Theta_JC. I would have expected Theta_JC as you described (bottom of part) to be an order of magnitude less than Theta_JA. Thanks, Mike
I don't disagree with you. They do seem closer than I would have expected. I wouldn't have guessed at an order of magnitude but I'd be guessing that junction to air would be two to three times higher. I looked at some other parts and see that they have similar junction to case thermal resistance and they seem to match on junction to case. So that is the number I would trust more. - Eamon
