inductor value on AMPOUT pin
The user inquired about a suitable 470 nH inductor for the AMPOUT pin (pin 29) of the HMC742A in a 500 MHz - 4 GHz project. The recommended part is the 0603LS-561XJLB from Coilcraft, as used on the HMC742A evaluation board.
Product Number: HMC742A
Hi team,
i'm using the HMC742A for a new project in the frequency range 500 MHz - 4 GHz.
In the datasheet there is an inducotor on AMPOUT pin (pin 29).
However, the datasheet does not specify a recommended part number or package for the 470 nH inductor. Could you please recommend a suitable part number that I can use?
Thank you in advance,
Matteo Ricci
Thread Notes
  • I recommend you use the value that is used on the evaluation board.  The L1 inductor part number is 0603LS-561XJLB from Colicraft. Here is the BOM for the HMC742A evaluation board.
    HMC742LP5 EVAL (70 - 1000 MHZ)
     QtyRefdesDescriptionManufacturer MFR Part Number
     1U10.5 DB LSB GAAS MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, 0.07 - 4 GHZADIHMC742ALP5E
     2J1-J2SCD, COMP, SMA CONNECTOR, JOHNSONJohnson Components142-0701-851
     1J3CONN HEADER 2MM 18 POS VERT SMTMolex87759-1850
     3J4-J6COMP, MILL-MAX DC PINMill-Max3101-2-00-21-00-00-08-0
     2SW1-SW2SPDT DIP SWITCH, SMT, 4 POS, SEALEDCTS Corporation204-124ST
     3C1,C6,C8CAP 10000PF 16V 10% CERAMIC X7R 0402MurataGRM155R71C103KA01D
     5C2-C5,C9CAP 1000PF 50V CERAMIC X7R 0402MurataGRM155R71H102KA01D
     1C7CAP CERM 100PF 5% 50V C0G 0402KemetC0402C101J5GACTU
     1C11CAP 1000PF 50V 10% CERAMIC X7R 0603MurataGRM188R71H102KA01D
     1C12CAP 5600PF 50V CERAMIC 0603 SMDMurata GRM188R71H562KA01D
     1C14CAP TANT 2.2UF 25V 10% SMD CASE AAVX Corp.TAJA225K025R
     14R1-R14RES 100K OHM 1/10W 1% 0402 SMDPanasonicERJ-2RKF1003X
     1R15RES ZERO OHM 1/4W 5% 1206 SMDPanasonicERJ-8GEY0R00V
     1L1Inductor, 560nH, 0603, 5%, .55 AmpCoilcraft0603LS-561XJLB
