ADAR2001ACCZ datasheet does not give any guidance on how to treat input pins MRST, MADV, TxRST, and TxADV if you are not using these pins. Should they be tied to GND, left floating, or pulled up to one of the power supply pins?
Thank you.
Strong EMC design
ADAR2001
Recommended for New Designs
The ADAR2001 is a transmitter IC optimized for millimeter wave body scanning applications. Accepting a single-ended continuous wave (CW) input signal between...
Datasheet
ADAR2001 on Analog.com
Thank you.
If you do not plan to use these pins to advance and reset the associated state machines, tie them all to ground.
