input matching
The user inquires about the optimal noise source impedance for the MAX2659 at pin 3, noting that the recommended 470 pF capacitor and 6.8 nH inductor may not achieve the desired impedance at 1.55 GHz due to parasitics. The final answer suggests that the recommended matching network is noise optimized, aiming for a 0.8 dB noise figure, and recommends using the s-parameters and exact component models (Murata LQW15AN6N8H00 and GRM155R71H471K) to simulate and optimize the layout for the user's specific application.
Category: Datasheet/Specs
Product Number: MAX2659
I need to know the optimal noise source impedance for your MAX2659, seen at pin 3. The data sheet specifies that I should use a 470 pF capacitance in series with 6.8 nH to convert 50 OHm to a suitable source impedance, but as latte correctly states in the question at "ez.analog.com/.../why-470pf-6-8nh" most 470 pF capacitors have a resonance frequency well below 1.55 GHz. They will thus NOT show a capacitive reactance at this frequency. Depending on type, the inductor will also have significant parasitics at this frequency. Hence the impedance at pin 3 on your test board may well be very different from what you will get in a series connection of ideal components of 50 ohm, 470pF and 6.8nH.
My layout and choice of components may well be different from what you have used on your test board. In order to obtain the performance you have obtained on the test board, I need to the impedance you actually experienced at pin 3 on your test board or at least which components (vendor and series) you have used on the test board, so I can simulate the parasitics.
  • I'll take a look at this and will get back to you once I know more. - Eamon
  • The s-parameters for the part are available on the website (https://www.analog.com/media/en/simulation-models/s-parameters/max2659.s2p).
    And fortunately, they are fully de-embedded.
    On the first screen shot below, I'm plotting the raw s-parameters (the input cap and inductor are shorted out). You can see poor return loss on the S11 curve.
    Next I included ideal 470pf and 6.8nF components and re-ran the sim. This shows improved S11. The S11 profile is not the same (or as good) as what you see in the datasheet. I put that down to the fact that I've not included the trace lengths from the eval boards and am also not using exact models for the components. I would imagine that those are available from the Manufacturer (see part numbers below).
    I think that the best path forward for you is to start with the raw s-parameters, add in the cap and inductor along with models for the trace lengths that separate them and then try to optimize the circuit for your needs. I'm also attaching a screen shot of the eval board bom which provides the manufacturers' part numbers for the input cap and inductor.
    L1 1 6.8nH 3% 0402 Inductor Murata LQW15AN6N8H00
    C1 1 470pF 10% 0402 Capacitor Murata GRM155R71H471K
  • Thank you for the quick response.
    I have measured S parameters similar to your de-embedded S-parameters.
    Based on the impedance conversion of your matching components, it seems that a complex conjugate matching is made to optimize for gain. However, I want to use the device as a Low Noise Amplifier and achieve the 0.8 dB NF reported in the data sheet. To do this I would typically convert my 50 Ohm source to the optimal noise source impedance seen at pin 3, rather than the optimal gain source impedance. These may not be the same!  If not, the gain is reduced, but the SNR at the output is reduced even more, so there is an overall SNR improvement in the system. Do you know what the optimal noise source impedance at pin 3 is for this device?
  • Let me do some digging to see what I can find out. I suspect though that the recommended matching network is noise optimized. The datasheet is saying that with the recommended components and placements, you should see a noise figure of 0.8 dB. Do you have an evaluation board for MAX2659 on hand to do any testing?
    Anyway, I'll try and find out if the matching network was designed to be noise optimized of gain optimized. I doubt that we have data on  GAMMAopt, that is, the ideal impedance that pin 3 should see. My guess is that the recommended components were identified using iteration in the lab. - Eamon
