I found out ADSimPLL and ADF4382 EVK results has difference in Phase noise in the 1k, 10k and 100kHz offset by 8 to 10dB. And, I use the same reference of 10MHz and phase noise table in the comparison which I changed from the original 125MHz Ref.. Also, I used the same loop filters in the simulation value and EVK for my 10MHz Ref. design.
Could someone help checking where I might be wrong between the simulation Vs. EVK results?
Thanks!
