MAX2771 noise issue due to VCCRF power rail
Product Number: MAX2771
I've been conducting some tests with the MAX2771 evaluation kit, to tune my design.
I am using the 3bit digital output configuration.
I've encountered an issue where the 2 magnitude bits sometimes disappear, or degrade to a point where the bit density doesn't match the value set by the AGC.
After some testing, I noticed that when I touch the RF input with something conductive, this causes a disruption to the ADC output, and from that moment the output is gone, even when I remove the interfering object.
My assumption was that this is due to some change in the noise pattern of the circuit, that causes the AGC to "go wild".
When performing the same "interference injection" to the MIX_IN line (or the LNA_OUT), this issue does not occur.
So, I assumed the issue was the LNA.
I then tried using an external LNA, and connect it to the MIX_IN, essentially bypassing the built-in LNA.
when performing the same test, only this time at the input of the external LNA, the same issue occurred.
Then I set the internal LNA to be disabled, and the issue still occurred.
finally, I completely disconnected the VCCRF pin (which I assumed powers the internal LNA), and the problem disappeared.
to summarize, there appears to be something about the VCCRF power rail that is very sensitive to noise and it disrupts the proper operation of the chip.
it seems that I can avoid this issue by using an external LNA, and not power the VCCRF rail.
my questions are:
1. Do you have any insight on this issue?
2. if I leave the VCCRF pin not connected, is there any essential circuitry in the chip that will be missing other than the LNA?
in other words, can I still use chip without the VCCRF powered?
