Use HMC8193 as IQ Modulator
Product Number: hmc8193
I was seeking for an I/Q modulator hat works up to 7.125GHz with good IP3, but did not find a proper part number. The HMC8193 seems to be an alter. In my application, QMC is applied to optimize sideband and LO leakage.
2 Questions I have;
1, Is there any known issue for using HMC8193 as IQ modulator? what is the 1dB IQ band with? Any known wideband(such as 5GNR, Wlan) EVM data?
2, HMC8193 datasheet (Page33) says Vcm = 0V, current < 6mA. My baseband DAC output Vcm = 0.25V, how to interface it to HMC8193?
TL
  • HMC8193 is a passive IQ mixer covering 2.5–8.5 GHz, suitable for ~7.125 GHz. Typical IP3 is ~+20 dBm and sideband performance is good, but wideband EVM for 5G NR/WLAN is not specified, so system-level testing is recommended.
    IF ports expect 0 V common-mode. With your DAC Vcm = 0.25 V, use AC coupling or a level-shift network to bring the signal to 0 V without exceeding ~6 mA DC.
