ADAR2001 cannot be properly enabled
The user encountered issues with the ADAR2001-ACCZ quadrupler chip where the internal power divider, buffer, and amplifier did not start normally after writing to registers 0x045, 0x046, 0x047, and 0x048. Despite correct SPI waveform and voltage, there was no output on SDO when reading registers 0x04F and 0x047. The final answer indicated that online support could not address the issue.
Product Number: ADAR2001
The ADAR2001-ACCZ quadrupler chip has normal power supply, with a VPOS pin voltage of 2.5V and a Vreg pin voltage of 1.9V, and the static power consumption is close to that in the datasheet. After writing to the 0x045, 0x046, 0x047, and 0x048 registers via four-wire SPI, the chip current does not change, indicating that the internal power divider, buffer, and amplifier of the chip are not starting normally. Subsequently, read commands were sent to the chip via SPI, attempting to read the values of registers 0x04F and 0x047, but there is no output on SDO. The SPI waveform was observed with an oscilloscope, and both the voltage and waveform were consistent with the chip datasheet. I would like to ask whether this is an issue with register configuration or a hardware design problem?
