EVAL-ADL5569: About how to use as Differential input and Single-end output
The user inquired about configuring the EVAL-ADL5569 for differential input and single-ended output. The final answer suggests connecting a 50 ohm resistor between the unused output and ground, with the used output connected to a load via an AC coupling capacitor. This configuration will result in a 6 dB lower voltage gain. The input stage is already set for differential input.
View FAQ
Product Number: ADL5569
Our customer is considering to use ADL5569.
About EVAL-ADL5569, he wants to use it that the condition is differential input and single-end output.
How does he change resisto value for use above condition?
I think the input stage is already for differential input but the output stage is not for single-end output.
I am understanding should change resistor of output stage for use single-end output.
Please tell me how to use EVAL-ADL5569 as the differential input and single-end output.
I am very happy if I can know concrete value of resistor.
Best Regards,
Tomohiro
Thread Notes
