Fault: No connection to EVB
The user is experiencing issues with the EVAL-SDP-CS1Z and EV-ADF4377SD1Z evaluation boards, where the software shows 'No Daughterboard Detected' despite a USB connection and correct power supply. The support engineer suspects a blank or corrupted EEPROM or issues with the I2C line. The user confirmed the 120-pin connector is seated correctly, the power supply polarity is correct, and the LEDs on both boards are lit. The user provided a log file and requested remote support due to project stress.
Product Number: EV-ADF4377SD1Z
Software Version: ACE 1.30.3369.1491 and board.adf4377.1.2022.16300.acezip
Hi
I am working with EVBs :
EVAL-SDP-CS1Z
EV-ADF4377SD1Z
But I don't have a connection as far as I understand I should see a connection when I see the software - green light and the component status is available
I attached the file board.adf4377.1.2022.16300.acezip to PLUG-IN
I have a USB connection I see it in the device manager
What else do I need to do to make it work I am using UG-2050 but without success
I attached a picture
I would appreciate a quick answer.
Thread Notes
  • Hi  ,
    Thanks for getting in touch and apologies for the delayed response,
    From your screenshots I can see that in the Attached Hardware section, the device is appearing as "No daughterboards detected".
    This indicates that ACE has detected the SDP-S controller board, but cannot detect the ADF4377 Eval board.
    There are a couple of possible causes for this, firstly I would advise checking the connection between the evaluation board and the SDP-S.
    The connection here is the long 120-pin white connector, please ensure that this is fully seated and there is no dust or debris in the connector socket.
    I also note that the EV-ADF4377SD1Z eval board requires a 6V external supply, provided to either the banana plug connectors or SMA connector.
    Please ensure that your power supply is connected and that the polarity is correct, this is required to power the evaluation board for communication with ACE.
    If neither of the above help, please try closing ACE and disconnecting your eval board setup, then open a new instance of ACE, connect the eval board, wait for the "No Daughterboards Detected" tile to show and then use the menu button in the top right of the screen. Select "Show Log File", then save the text file and upload it here in a reply so that we can debug further.
    Thanks
    Eoin
  • Hi Eoin
    Thanks for the reply
    I checked the options and it seems to be working
    Attaching the file log
    16:06:45 AceCore is setting environment variables
    16:06:45 AceCore is setting required default culture
    16:06:45 AceCore is initializing the IOC container
    16:06:46 AceCore is adding facilities
    16:06:46 AceCore is registering components
    16:06:46 Current FFT implementation is AnalogDevices.Csa.Evaluation.Analyzers.CommonFFT.CommonFFTAnalyzer
    16:06:53 Configuring package provider.
    16:06:53 PackageProvider is creating the background worker.
    16:06:53 PackageProvider is building the list of sources.
    16:06:53 InstalledPackageSourceReader is looking for installed packages.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.DeviceApiSupport 1.2022.28200.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.DeviceApiSupport 1.2022.28200 in 51.661ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.HsdacSupport 1.2022.28200.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.HsdacSupport 1.2022.28200 in 0.274ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.IIOSupport 1.2025.2621058.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.IIOSupport 1.2025.2621058 in 4.959ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.LinduinoSupport 1.2023.27300.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.LinduinoSupport 1.2023.27300 in 7.233ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.SdpSupport 1.2024.34500.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.SdpSupport 1.2024.34500 in 0.199ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.UnifiedSpiMaster 1.2022.28400.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.UnifiedSpiMaster 1.2022.28400 in 0.143ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Hardware.ClockSupport 1.2022.28200.
    16:06:53 InstalledPackageSourceReader found plug-in for Hardware.ClockSupport 1.2022.28200 in 0.131ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.Generic 1.2021.28300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.Generic 1.2021.28300 in 0.123ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.GenericFpga 1.2021.46402.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.GenericFpga 1.2021.46402 in 0.143ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.CsaControllers 1.2023.43100.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.CsaControllers 1.2023.43100 in 0.144ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.Linduino 1.2021.29300.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.Linduino 1.2021.29300 in 0.136ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Vector.Common 1.30.3369.
    16:06:53 InstalledPackageSourceReader found plug-in for Vector.Common 1.30.3369 in 0.125ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Vector.File 1.30.3369.
    16:06:53 InstalledPackageSourceReader found plug-in for Vector.File 1.30.3369 in 0.127ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.ADF4371 1.2022.3300.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.ADF4371 1.2022.3300 in 0.151ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.ADF4377 1.2022.16300.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.ADF4377 1.2022.16300 in 0.143ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.ADF4371 1.2022.24300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.ADF4371 1.2022.24300 in 0.135ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.ADF4377 1.2022.15100.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.ADF4377 1.2022.15100 in 0.141ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.BlockGallery 1.2024.23300.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.BlockGallery 1.2024.23300 in 0.127ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.IIO 1.2025.2611551.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.IIO 1.2025.2611551 in 2.857ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.IronPython 1.2023.38300.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.IronPython 1.2023.38300 in 0.232ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.Keyring 1.2025.2131054.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.Keyring 1.2025.2131054 in 0.142ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.Lexicon 1.2025.1251649.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.Lexicon 1.2025.1251649 in 0.153ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.NationalInstruments.MeasurementStudio 15.0.187.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.NationalInstruments.MeasurementStudio 15.0.187 in 0.138ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.ScriptRunner 1.2023.19300.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.ScriptRunner 1.2023.19300 in 0.131ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Support.Transactions 1.2023.47200.
    16:06:53 InstalledPackageSourceReader found plug-in for Support.Transactions 1.2023.47200 in 0.132ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD738X 1.2024.38500.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD738X 1.2024.38500 in 0.127ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.AD738X 1.2024.38300.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.AD738X 1.2024.38300 in 0.159ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9161 1.2020.24300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9161 1.2020.24300 in 0.124ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9162 1.2020.24300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9162 1.2020.24300 in 0.124ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9163 1.2020.24300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9163 1.2020.24300 in 0.123ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9164 1.2020.24300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9164 1.2020.24300 in 0.12ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9508 1.2.0.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9508 1.2.0 in 0.113ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.ADF4355 1.1.1.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.ADF4355 1.1.1 in 0.113ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.AD9162 1.2020.47400.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.AD9162 1.2020.47400 in 0.147ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9172 1.2021.32300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9172 1.2021.32300 in 0.122ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9528 1.1.2.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9528 1.1.2 in 0.107ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.HMC7044 0.1.0.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.HMC7044 0.1.0 in 0.113ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.AD9172 1.2020.8500.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.AD9172 1.2020.8500 in 0.153ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9208 1.2022.20500.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9208 1.2022.20500 in 0.12ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.AD9208 1.2022.20500.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.AD9208 1.2022.20500 in 0.14ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9689 1.2020.33400.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9689 1.2020.33400 in 0.134ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.AD9689 1.2020.6400.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.AD9689 1.2020.6400 in 0.138ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.AD9695 1.2023.48400.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.AD9695 1.2023.48400 in 0.118ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.AD9695 1.2023.48400.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.AD9695 1.2023.48400 in 0.137ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.ADA2200 1.10.2.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.ADA2200 1.10.2 in 0.126ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.ADA2200 1.2025.1241419.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.ADA2200 1.2025.1241419 in 0.147ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.ADF4372 1.2022.24300.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.ADF4372 1.2022.24300 in 0.139ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.ADF4372 1.2020.5500.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.ADF4372 1.2020.5500 in 0.148ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Chip.ADMV1013 0.1.5.
    16:06:53 InstalledPackageSourceReader found plug-in for Chip.ADMV1013 0.1.5 in 0.134ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.ADMV1013 1.2019.9400.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.ADMV1013 1.2019.9400 in 0.137ms.
    16:06:53 InstalledPackageSourceReader is finding plug-in for Board.LegacyQevModules 1.2021.28300.
    16:06:53 InstalledPackageSourceReader found plug-in for Board.LegacyQevModules 1.2021.28300 in 0.139ms.
    16:06:53 InstalledPackageSourceReader is finished finding plug-ins for installed packages in 77.929ms
    16:06:53 Server manager started remote control server on port number 2357
    16:06:53 AnalogDevices.Csa.App.Wpf.Usage.ACEUsageLoggingProvider is using table name suffix "" for application usage logging
    16:06:53 Restoring configuration settings from C:\Users\user\AppData\Local\Analog Devices\ACE\UserSettings\Configuration.Settings.xml
    16:06:54 Clearing blocked plug-ins.
    16:06:54 Scanning folder "C:\ProgramData\Analog Devices\ACE\Plugins" for plug-ins.
    16:06:54 Lookup time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 0.241ms
    16:06:54 Lookup time for plug-in Vector.File, Version 1.30.3369 was 0.005ms
    16:06:54 Lookup time for plug-in Support.Transactions, Version 1.2023.47200 was 0.006ms
    16:06:54 Lookup time for plug-in Support.IIO, Version 1.2025.2611551 was 0.004ms
    16:06:54 Lookup time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 0.019ms
    16:06:54 Lookup time for plug-in Chip.AD9164, Version 1.2020.24300 was 0.006ms
    16:06:54 Lookup time for plug-in Hardware.SdpSupport, Version 1.2024.34500 was 0.006ms
    16:06:54 Lookup time for plug-in Chip.HMC7044, Version 0.1.0 was 0.011ms
    16:06:54 Assembly registration time for plug-in Vector.File, Version 1.30.3369 was 0.822ms
    16:06:54 Assembly registration time for plug-in Support.Transactions, Version 1.2023.47200 was 12.563ms
    16:06:54 Assembly registration time for plug-in Hardware.SdpSupport, Version 1.2024.34500 was 12.503ms
    16:06:54 Assembly registration time for plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 was 1.41ms
    16:06:54 Loaded Extensions - Plug-in Hardware.DeviceApiSupport, Version 1.2022.28200 - 289.608ms
    16:06:54 Loaded Extensions - Plug-in Support.Transactions, Version 1.2023.47200 - 289.859ms
    16:06:54 Plug-in Hardware.DeviceApiSupport Validation Error: Object reference not set to an instance of an object.
    System.NullReferenceException: Object reference not set to an instance of an object.
    at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
    at AnalogDevices.Csa.CastleSupport.Plugins.Extensions.CompositeExtensionLoader.AddLoader(ILazyComponentLoader loader)
    at AnalogDevices.Csa.CastleSupport.Plugins.Extensions.WindsorExtensionPointManager.DoLoadExtensions(IPlugin plugin)
    at AnalogDevices.Csa.Plugins.Extensions.ExtensionPointManager.LoadExtensions(IPlugin plugin)
    at AnalogDevices.Csa.PackageManagement.Plugins.NugetLocalPackagePlugin..ctor(PluginRepository repository, INugetPluginFolderInfo info, String extensionsFilePath)
    at AnalogDevices.Csa.PackageManagement.Plugins.NugetPackagePluginFactory.TryCreatePlugin(INugetPluginFolderInfo info, PluginRepository repository, IPlugin& plugin)
    at AnalogDevices.Csa.Plugins.PluginFactoryBase.CreatePlugin(INugetPluginFolderInfo info, PluginRepository repository)
    at AnalogDevices.Csa.Plugins.PluginRepository.DoLoadPlugin(INugetPluginFolderInfo info)
    at AnalogDevices.Csa.Plugins.PluginRepository.LoadPlugin(INugetPluginFolderInfo info)
    16:06:54 Plug-in Support.Transactions Validation Error: Object reference not set to an instance of an object.
    16:06:54 Lookup time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 0.01ms
    16:06:54 Lookup time for plug-in Chip.AD738X, Version 1.2024.38500 was 0.007ms
    16:06:54 Assembly registration time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 0.726ms
    16:06:54 Assembly registration time for plug-in Chip.AD9164, Version 1.2020.24300 was 7.127ms
    16:06:54 Castle.MicroKernel.ComponentActivator.ComponentActivatorException: ComponentActivator: could not instantiate AnalogDevices.Csa.Hardware.HsdacSupport.HsdacControllerFinder ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.FileNotFoundException: Could not load file or assembly 'AnalogDevices.DPG.EvaluationBoards, Version=1.0.0.0, Culture=neutral, PublicKeyToken=cf4fed3ab3d3bf1a' or one of its dependencies. The system cannot find the file specified.
    at AnalogDevices.Csa.Hardware.HsdacSupport.HsdacControllerFinder..ctor(IEvalComponentRepository repo, ITransactionBroker handlerBroker)
    --- End of inner exception stack trace ---
    at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
    at System.Reflection.RuntimeConstructorInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
    at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.FastCreateInstance(Type implType, Object[] arguments, ConstructorCandidate constructor)
    at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateInstanceCore(ConstructorCandidate constructor, Object[] arguments, Type implType)
    at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.CreateInstance(CreationContext context, ConstructorCandidate constructor, Object[] arguments)
    at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.Instantiate(CreationContext context)
    at Castle.MicroKernel.ComponentActivator.DefaultComponentActivator.InternalCreate(CreationContext context)
    at Castle.MicroKernel.ComponentActivator.AbstractComponentActivator.Create(CreationContext context, Burden burden)
    at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.CreateInstance(CreationContext context, Boolean trackedExternally)
    at Castle.MicroKernel.Lifestyle.AbstractLifestyleManager.Resolve(CreationContext context, IReleasePolicy releasePolicy)
    at Castle.MicroKernel.Handlers.DefaultHandler.ResolveCore(CreationContext context, Boolean requiresDecommission, Boolean instanceRequired, Burden& burden)
    at Castle.MicroKernel.Handlers.DefaultHandler.Resolve(CreationContext context, Boolean instanceRequired)
    at Castle.MicroKernel.Handlers.AbstractHandler.Resolve(CreationContext context)
    at Castle.MicroKernel.DefaultKernel.ResolveComponent(IHandler handler, Type service, Arguments additionalArguments, IReleasePolicy policy, Boolean ignoreParentContext)
    at Castle.MicroKernel.DefaultKernel.ResolveComponent(IHandler handler, Type service, Arguments additionalArguments, IReleasePolicy policy)
    at Castle.MicroKernel.DefaultKernel.Castle.MicroKernel.IKernelInternal.Resolve(String key, Type service, Arguments arguments, IReleasePolicy policy)
    at Castle.Facilities.TypedFactory.TypedFactoryComponentResolver.Resolve(IKernelInternal kernel, IReleasePolicy scope)
    at Castle.Facilities.TypedFactory.Internal.TypedFactoryInterceptor.Resolve(IInvocation invocation)
    at Castle.Facilities.TypedFactory.Internal.TypedFactoryInterceptor.Intercept(IInvocation invocation)
    at Castle.DynamicProxy.AbstractInvocation.Proceed()
    at AnalogDevices.Csa.CastleSupport.FactoryInterceptor.Intercept(IInvocation invocation)
    16:06:54 Loaded Extensions - Plug-in Chip.AD9164, Version 1.2020.24300 - 39.529ms
    16:06:54 Initialization time for plug-in Chip.AD9164, Version 1.2020.24300 was 343.275ms
    16:06:54 Loaded plug-in Chip.AD9164, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9164.1.2020.24300 in 343.456ms
    16:06:54 Lookup time for plug-in Chip.AD9508, Version 1.2.0 was 0.013ms
    16:06:54 Plug-in Hardware.HsdacSupport.HsdacControllerFinder Validation Error: Error registering controller finder
    System.ArgumentNullException: finder cannot be null
    Parameter name: finder
    at AnalogDevices.Csa.ValidationExtensions.AssertNotNull(Object instance, String name, String message)
    at AnalogDevices.Csa.Hardware.AggregateFinder.RegisterFinder(String id, IControllerFinder finder)
    at AnalogDevices.Csa.Hardware.AggregateFinder.DoProcess(Extension extension)
    16:06:54 Loaded Extensions - Plug-in Hardware.HsdacSupport, Version 1.2022.28200 - 34.07ms
    16:06:54 Initialization time for plug-in Hardware.HsdacSupport, Version 1.2022.28200 was 34.653ms
    16:06:54 Loaded plug-in Hardware.HsdacSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.HsdacSupport.1.2022.28200 in 34.827ms
    16:06:54 Lookup time for plug-in Hardware.IIOSupport, Version 1.2025.2621058 was 0.01ms
    16:06:54 Assembly registration time for plug-in Hardware.IIOSupport, Version 1.2025.2621058 was 1.5ms
    16:06:54 Loaded Extensions - Plug-in Vector.File, Version 1.30.3369 - 355.982ms
    16:06:54 Initialization time for plug-in Vector.File, Version 1.30.3369 was 368.229ms
    16:06:54 Loaded plug-in Vector.File, Version 1.30.3369 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.File.1.30.3369 in 370.744ms
    16:06:54 Lookup time for plug-in Board.ADF4371, Version 1.2022.3300 was 0.016ms
    16:06:54 Lookup time for plug-in Chip.ADF4371, Version 1.2022.24300 was 0.005ms
    16:06:54 Loaded Extensions - Plug-in Hardware.IIOSupport, Version 1.2025.2621058 - 25.274ms
    16:06:54 Initialization time for plug-in Hardware.IIOSupport, Version 1.2025.2621058 was 25.889ms
    16:06:54 Loaded plug-in Hardware.IIOSupport, Version 1.2025.2621058 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.IIOSupport.1.2025.2621058 in 26.014ms
    16:06:54 Lookup time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 0.006ms
    16:06:54 Dependency Hardware.SdpSupport loaded in 0.189ms
    16:06:54 Assembly registration time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 0.744ms
    16:06:54 Assembly registration time for plug-in Chip.HMC7044, Version 0.1.0 was 67.594ms
    16:06:54 Loaded Extensions - Plug-in Chip.HMC7044, Version 0.1.0 - 83.984ms
    16:06:54 Initialization time for plug-in Chip.HMC7044, Version 0.1.0 was 299.115ms
    16:06:54 Loaded plug-in Chip.HMC7044, Version 0.1.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.HMC7044.0.1.0 in 299.311ms
    16:06:54 Lookup time for plug-in Board.AD9172, Version 1.2020.8500 was 0.007ms
    16:06:54 Assembly registration time for plug-in Chip.ADF4371, Version 1.2022.24300 was 0.906ms
    16:06:54 Loaded Extensions - Plug-in Chip.ADF4371, Version 1.2022.24300 - 14.644ms
    16:06:54 Initialization time for plug-in Chip.ADF4371, Version 1.2022.24300 was 16.851ms
    16:06:54 Dependency Chip.ADF4371 loaded in 17.188ms
    16:06:54 Assembly registration time for plug-in Board.ADF4371, Version 1.2022.3300 was 0.661ms
    16:06:54 Loaded Extensions - Plug-in Hardware.LinduinoSupport, Version 1.2023.27300 - 22.416ms
    16:06:54 Initialization time for plug-in Hardware.LinduinoSupport, Version 1.2023.27300 was 23.388ms
    16:06:54 Loaded plug-in Hardware.LinduinoSupport, Version 1.2023.27300 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.LinduinoSupport.1.2023.27300 in 23.516ms
    16:06:54 Loaded plug-in Hardware.SdpSupport, Version 1.2024.34500 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.SdpSupport.1.2024.34500 in 0.004ms
    16:06:54 Lookup time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 0.008ms
    16:06:54 Assembly registration time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 0.758ms
    16:06:54 Loaded Extensions - Plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 - 1.035ms
    16:06:54 Initialization time for plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 was 1.594ms
    16:06:54 Loaded plug-in Hardware.UnifiedSpiMaster, Version 1.2022.28400 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.UnifiedSpiMaster.1.2022.28400 in 1.715ms
    16:06:54 Lookup time for plug-in Chip.Generic, Version 1.2021.28300 was 0.009ms
    16:06:54 Assembly registration time for plug-in Chip.Generic, Version 1.2021.28300 was 0.662ms
    16:06:54 Loaded Extensions - Plug-in Chip.Generic, Version 1.2021.28300 - 1.256ms
    16:06:54 Initialization time for plug-in Chip.Generic, Version 1.2021.28300 was 1.82ms
    16:06:54 Loaded plug-in Chip.Generic, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.Generic.1.2021.28300 in 1.935ms
    16:06:54 Lookup time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 0.007ms
    16:06:54 Dependency Hardware.SdpSupport loaded in 0.188ms
    16:06:54 Loaded Extensions - Plug-in Board.ADF4371, Version 1.2022.3300 - 13.807ms
    16:06:54 Initialization time for plug-in Board.ADF4371, Version 1.2022.3300 was 32.153ms
    16:06:54 Loaded plug-in Board.ADF4371, Version 1.2022.3300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4371.1.2022.3300 in 32.281ms
    16:06:54 Lookup time for plug-in Board.ADF4377, Version 1.2022.16300 was 0.008ms
    16:06:54 Assembly registration time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 0.679ms
    16:06:54 Loaded Extensions - Plug-in Chip.GenericFpga, Version 1.2021.46402 - 1.297ms
    16:06:54 Initialization time for plug-in Chip.GenericFpga, Version 1.2021.46402 was 2.228ms
    16:06:54 Loaded plug-in Chip.GenericFpga, Version 1.2021.46402 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.GenericFpga.1.2021.46402 in 2.325ms
    16:06:54 Lookup time for plug-in Board.CsaControllers, Version 1.2023.43100 was 0.007ms
    16:06:54 Lookup time for plug-in Chip.ADF4377, Version 1.2022.15100 was 0.004ms
    16:06:54 Dependency Hardware.SdpSupport loaded in 0.162ms
    16:06:54 Assembly registration time for plug-in Board.CsaControllers, Version 1.2023.43100 was 0.781ms
    16:06:54 Assembly registration time for plug-in Chip.ADF4377, Version 1.2022.15100 was 0.76ms
    16:06:54 Loaded Extensions - Plug-in Board.CsaControllers, Version 1.2023.43100 - 15.284ms
    16:06:54 Loaded Extensions - Plug-in Chip.ADF4377, Version 1.2022.15100 - 13.834ms
    16:06:54 Initialization time for plug-in Board.CsaControllers, Version 1.2023.43100 was 16.324ms
    16:06:54 Loaded plug-in Board.CsaControllers, Version 1.2023.43100 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.CsaControllers.1.2023.43100 in 16.431ms
    16:06:54 Lookup time for plug-in Board.Linduino, Version 1.2021.29300 was 0.009ms
    16:06:54 Initialization time for plug-in Chip.ADF4377, Version 1.2022.15100 was 16.203ms
    16:06:54 Dependency Chip.ADF4377 loaded in 16.803ms
    16:06:54 Assembly registration time for plug-in Board.ADF4377, Version 1.2022.16300 was 0.689ms
    16:06:54 Loaded Extensions - Plug-in Board.ADF4377, Version 1.2022.16300 - 1.426ms
    16:06:54 Initialization time for plug-in Board.ADF4377, Version 1.2022.16300 was 19.015ms
    16:06:54 Loaded plug-in Board.ADF4377, Version 1.2022.16300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4377.1.2022.16300 in 19.115ms
    16:06:54 Loaded plug-in Chip.ADF4371, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4371.1.2022.24300 in 0.004ms
    16:06:54 Loaded plug-in Chip.ADF4377, Version 1.2022.15100 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4377.1.2022.15100 in 0.002ms
    16:06:54 Lookup time for plug-in Support.BlockGallery, Version 1.2024.23300 was 0.006ms
    16:06:54 Assembly registration time for plug-in Board.Linduino, Version 1.2021.29300 was 0.744ms
    16:06:54 Loaded Extensions - Plug-in Board.Linduino, Version 1.2021.29300 - 6.365ms
    16:06:54 Initialization time for plug-in Board.Linduino, Version 1.2021.29300 was 6.975ms
    16:06:54 Loaded plug-in Board.Linduino, Version 1.2021.29300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.Linduino.1.2021.29300 in 7.118ms
    16:06:54 Lookup time for plug-in Vector.Common, Version 1.30.3369 was 0.009ms
    16:06:54 Assembly registration time for plug-in Chip.AD9508, Version 1.2.0 was 50.54ms
    16:06:54 Loaded Extensions - Plug-in Chip.AD9508, Version 1.2.0 - 78.342ms
    16:06:54 Initialization time for plug-in Chip.AD9508, Version 1.2.0 was 98.262ms
    16:06:54 Loaded plug-in Chip.AD9508, Version 1.2.0 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9508.1.2.0 in 98.379ms
    16:06:54 Lookup time for plug-in Chip.ADF4355, Version 1.1.1 was 0.007ms
    16:06:54 Assembly registration time for plug-in Support.BlockGallery, Version 1.2024.23300 was 0.683ms
    16:06:54 Assembly registration time for plug-in Vector.Common, Version 1.30.3369 was 0.962ms
    16:06:54 Loaded Extensions - Plug-in Vector.Common, Version 1.30.3369 - 74.717ms
    16:06:54 Initialization time for plug-in Vector.Common, Version 1.30.3369 was 75.339ms
    16:06:54 Loaded plug-in Vector.Common, Version 1.30.3369 from C:\ProgramData\Analog Devices\ACE\Plugins\Vector.Common.1.30.3369 in 75.456ms
    16:06:54 Lookup time for plug-in Support.IronPython, Version 1.2023.38300 was 0.009ms
    16:06:54 Assembly registration time for plug-in Support.IronPython, Version 1.2023.38300 was 0.642ms
    16:06:54 Loaded Extensions - Plug-in Support.IronPython, Version 1.2023.38300 - 3.886ms
    16:06:54 Initialization time for plug-in Support.IronPython, Version 1.2023.38300 was 4.488ms
    16:06:54 Loaded plug-in Support.IronPython, Version 1.2023.38300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IronPython.1.2023.38300 in 4.606ms
    16:06:54 Lookup time for plug-in Support.Keyring, Version 1.2025.2131054 was 0.015ms
    16:06:54 Assembly registration time for plug-in Support.Keyring, Version 1.2025.2131054 was 0.648ms
    16:06:54 Loaded Extensions - Plug-in Support.Keyring, Version 1.2025.2131054 - 0.923ms
    16:06:54 Initialization time for plug-in Support.Keyring, Version 1.2025.2131054 was 5.355ms
    16:06:54 Loaded plug-in Support.Keyring, Version 1.2025.2131054 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.Keyring.1.2025.2131054 in 5.523ms
    16:06:54 Lookup time for plug-in Support.Lexicon, Version 1.2025.1251649 was 0.009ms
    16:06:54 Assembly registration time for plug-in Support.Lexicon, Version 1.2025.1251649 was 0.599ms
    16:06:54 Loaded Extensions - Plug-in Support.Lexicon, Version 1.2025.1251649 - 1.045ms
    16:06:54 Initialization time for plug-in Support.Lexicon, Version 1.2025.1251649 was 5.304ms
    16:06:54 Loaded plug-in Support.Lexicon, Version 1.2025.1251649 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.Lexicon.1.2025.1251649 in 5.451ms
    16:06:54 Lookup time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 0.009ms
    16:06:54 Lookup time for plug-in Chip.AD9528, Version 1.1.2 was 0.006ms
    16:06:54 Assembly registration time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 245.582ms
    16:06:54 Assembly registration time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 32.269ms
    16:06:54 Loaded Extensions - Plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 - 34.02ms
    16:06:54 Initialization time for plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 was 34.528ms
    16:06:54 Loaded plug-in Support.NationalInstruments.MeasurementStudio, Version 15.0.187 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.NationalInstruments.MeasurementStudio.15.0.187 in 34.642ms
    16:06:54 Lookup time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 0.008ms
    16:06:54 Assembly registration time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 0.532ms
    16:06:54 Loaded Extensions - Plug-in Support.ScriptRunner, Version 1.2023.19300 - 1.077ms
    16:06:54 Initialization time for plug-in Support.ScriptRunner, Version 1.2023.19300 was 1.573ms
    16:06:54 Loaded plug-in Support.ScriptRunner, Version 1.2023.19300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.ScriptRunner.1.2023.19300 in 1.689ms
    16:06:54 Lookup time for plug-in Chip.AD9161, Version 1.2020.24300 was 0.007ms
    16:06:54 Loaded Extensions - Plug-in Hardware.ClockSupport, Version 1.2022.28200 - 543.736ms
    16:06:54 Initialization time for plug-in Hardware.ClockSupport, Version 1.2022.28200 was 556.913ms
    16:06:54 Loaded plug-in Hardware.ClockSupport, Version 1.2022.28200 from C:\ProgramData\Analog Devices\ACE\Plugins\Hardware.ClockSupport.1.2022.28200 in 559.752ms
    16:06:54 Lookup time for plug-in Board.AD9162, Version 1.2020.47400 was 0.005ms
    16:06:54 Assembly registration time for plug-in Chip.AD9161, Version 1.2020.24300 was 40.826ms
    16:06:54 Loaded Extensions - Plug-in Chip.AD9161, Version 1.2020.24300 - 43.277ms
    16:06:54 Initialization time for plug-in Chip.AD9161, Version 1.2020.24300 was 43.918ms
    16:06:54 Loaded plug-in Chip.AD9161, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9161.1.2020.24300 in 44.009ms
    16:06:54 Lookup time for plug-in Chip.AD9162, Version 1.2020.24300 was 0.007ms
    16:06:54 Assembly registration time for plug-in Chip.AD9162, Version 1.2020.24300 was 14.541ms
    16:06:54 Loaded Extensions - Plug-in Chip.AD9162, Version 1.2020.24300 - 16.665ms
    16:06:54 Initialization time for plug-in Chip.AD9162, Version 1.2020.24300 was 17.36ms
    16:06:54 Loaded plug-in Chip.AD9162, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9162.1.2020.24300 in 17.47ms
    16:06:54 Lookup time for plug-in Chip.AD9163, Version 1.2020.24300 was 0.009ms
    16:06:54 Assembly registration time for plug-in Chip.AD9163, Version 1.2020.24300 was 30.202ms
    16:06:54 Loaded Extensions - Plug-in Chip.AD9163, Version 1.2020.24300 - 32.631ms
    16:06:54 Dependency Chip.ADF4355 loaded in 0.158ms
    16:06:54 Initialization time for plug-in Chip.AD9163, Version 1.2020.24300 was 33.347ms
    16:06:54 Loaded plug-in Chip.AD9163, Version 1.2020.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9163.1.2020.24300 in 33.465ms
    16:06:54 Loaded plug-in Chip.AD9528, Version 1.1.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9528.1.1.2 in 0.002ms
    16:06:54 Lookup time for plug-in Board.AD9208, Version 1.2022.20500 was 0.015ms
    16:06:54 Assembly registration time for plug-in Chip.ADF4355, Version 1.1.1 was 38.52ms
    16:06:54 Loaded Extensions - Plug-in Chip.ADF4355, Version 1.1.1 - 144.487ms
    16:06:54 Initialization time for plug-in Chip.ADF4355, Version 1.1.1 was 214.187ms
    16:06:54 Loaded plug-in Chip.ADF4355, Version 1.1.1 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4355.1.1.1 in 214.296ms
    16:06:54 Lookup time for plug-in Chip.AD9695, Version 1.2023.48400 was 0.016ms
    16:06:54 Lookup time for plug-in Chip.AD9208, Version 1.2022.20500 was 0.009ms
    16:06:54 Assembly registration time for plug-in Chip.AD9528, Version 1.1.2 was 82.977ms
    16:06:54 Loaded Extensions - Plug-in Chip.AD9528, Version 1.1.2 - 195.205ms
    16:06:54 Initialization time for plug-in Chip.AD9528, Version 1.1.2 was 218.422ms
    16:06:54 Dependency Chip.AD9528 loaded in 218.784ms
    16:06:54 Lookup time for plug-in Chip.AD9172, Version 1.2021.32300 was 0.006ms
    16:06:54 Assembly registration time for plug-in Board.AD9162, Version 1.2020.47400 was 7.754ms
    16:06:54 Loaded Extensions - Plug-in Board.AD9162, Version 1.2020.47400 - 184.453ms
    16:06:54 Initialization time for plug-in Board.AD9162, Version 1.2020.47400 was 275.041ms
    16:06:54 Loaded plug-in Board.AD9162, Version 1.2020.47400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9162.1.2020.47400 in 275.183ms
    16:06:54 Loaded plug-in Chip.AD9172, Version 1.2021.32300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9172.1.2021.32300 in 0.004ms
    16:06:54 Lookup time for plug-in Chip.ADF4372, Version 1.2022.24300 was 0.008ms
    16:06:54 Assembly registration time for plug-in Chip.AD9172, Version 1.2021.32300 was 7.384ms
    16:06:54 Loaded Extensions - Plug-in Chip.AD9172, Version 1.2021.32300 - 98.405ms
    16:06:54 Initialization time for plug-in Chip.AD9172, Version 1.2021.32300 was 169.802ms
    16:06:54 Dependency Chip.AD9172 loaded in 170.114ms
    16:06:55 Assembly registration time for plug-in Chip.AD738X, Version 1.2024.38500 was 358.772ms
    16:06:55 Loaded Extensions - Plug-in Chip.AD738X, Version 1.2024.38500 - 672.608ms
    16:06:55 Initialization time for plug-in Chip.AD738X, Version 1.2024.38500 was 698.169ms
    16:06:55 Loaded plug-in Chip.AD738X, Version 1.2024.38500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD738X.1.2024.38500 in 698.332ms
    16:06:55 Lookup time for plug-in Board.AD738X, Version 1.2024.38300 was 0.009ms
    16:06:55 Dependency Support.BlockGallery loaded in 0.161ms
    16:06:55 Error restoring user settings: Could not find file 'C:\Users\user\AppData\Local\Analog Devices\ACE\UserSettings\Evaluation.Settings.xml'.
    16:06:55 Loaded Extensions - Plug-in Support.BlockGallery, Version 1.2024.23300 - 688.29ms
    16:06:55 Initialization time for plug-in Support.BlockGallery, Version 1.2024.23300 was 688.904ms
    16:06:55 Loaded plug-in Support.BlockGallery, Version 1.2024.23300 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.BlockGallery.1.2024.23300 in 689.029ms
    16:06:55 Lookup time for plug-in Chip.ADMV1013, Version 0.1.5 was 0.008ms
    16:06:55 Assembly registration time for plug-in Board.AD738X, Version 1.2024.38300 was 62.761ms
    16:06:55 Assembly registration time for plug-in Chip.ADF4372, Version 1.2022.24300 was 258.938ms
    16:06:55 Loaded Extensions - Plug-in Chip.ADF4372, Version 1.2022.24300 - 286.766ms
    16:06:55 Initialization time for plug-in Chip.ADF4372, Version 1.2022.24300 was 327.803ms
    16:06:55 Loaded plug-in Chip.ADF4372, Version 1.2022.24300 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADF4372.1.2022.24300 in 327.912ms
    16:06:55 Lookup time for plug-in Board.ADF4372, Version 1.2020.5500 was 0.008ms
    16:06:55 Assembly registration time for plug-in Chip.AD9695, Version 1.2023.48400 was 367.761ms
    16:06:55 Assembly registration time for plug-in Chip.AD9208, Version 1.2022.20500 was 394.422ms
    16:06:55 Loaded Extensions - Plug-in Chip.AD9695, Version 1.2023.48400 - 500.917ms
    16:06:55 Loaded Extensions - Plug-in Chip.AD9208, Version 1.2022.20500 - 461.767ms
    16:06:55 Initialization time for plug-in Chip.AD9695, Version 1.2023.48400 was 540.541ms
    16:06:55 Loaded plug-in Chip.AD9695, Version 1.2023.48400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9695.1.2023.48400 in 540.67ms
    16:06:55 Lookup time for plug-in Board.AD9695, Version 1.2023.48400 was 0.007ms
    16:06:55 Initialization time for plug-in Chip.AD9208, Version 1.2022.20500 was 517.946ms
    16:06:55 Dependency Chip.AD9208 loaded in 518.6ms
    16:06:55 Assembly registration time for plug-in Board.AD9172, Version 1.2020.8500 was 7.451ms
    16:06:55 Loaded Extensions - Plug-in Board.AD738X, Version 1.2024.38300 - 197.791ms
    16:06:55 Initialization time for plug-in Board.AD738X, Version 1.2024.38300 was 198.942ms
    16:06:55 Loaded plug-in Board.AD738X, Version 1.2024.38300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD738X.1.2024.38300 in 199.069ms
    16:06:55 Assembly registration time for plug-in Board.ADF4372, Version 1.2020.5500 was 13.399ms
    16:06:55 Loaded Extensions - Plug-in Board.ADF4372, Version 1.2020.5500 - 27.061ms
    16:06:55 Initialization time for plug-in Board.ADF4372, Version 1.2020.5500 was 63.646ms
    16:06:55 Loaded plug-in Board.ADF4372, Version 1.2020.5500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADF4372.1.2020.5500 in 63.774ms
    16:06:55 Loaded Extensions - Plug-in Board.AD9172, Version 1.2020.8500 - 311.588ms
    16:06:55 Initialization time for plug-in Board.AD9172, Version 1.2020.8500 was 849.594ms
    16:06:55 Loaded plug-in Board.AD9172, Version 1.2020.8500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9172.1.2020.8500 in 849.726ms
    16:06:55 Loaded plug-in Chip.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9208.1.2022.20500 in 0.003ms
    16:06:55 Assembly registration time for plug-in Board.AD9208, Version 1.2022.20500 was 71.962ms
    16:06:55 Assembly registration time for plug-in Board.AD9695, Version 1.2023.48400 was 70.843ms
    16:06:55 Loaded Extensions - Plug-in Board.AD9208, Version 1.2022.20500 - 73.425ms
    16:06:55 Initialization time for plug-in Board.AD9208, Version 1.2022.20500 was 624.558ms
    16:06:55 Loaded plug-in Board.AD9208, Version 1.2022.20500 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9208.1.2022.20500 in 624.701ms
    16:06:55 Lookup time for plug-in Chip.AD9689, Version 1.2020.33400 was 0.009ms
    16:06:55 Loaded Extensions - Plug-in Board.AD9695, Version 1.2023.48400 - 74.59ms
    16:06:55 Initialization time for plug-in Board.AD9695, Version 1.2023.48400 was 75.649ms
    16:06:55 Loaded plug-in Board.AD9695, Version 1.2023.48400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9695.1.2023.48400 in 75.753ms
    16:06:55 Lookup time for plug-in Chip.ADA2200, Version 1.10.2 was 0.007ms
    16:06:55 Assembly registration time for plug-in Chip.AD9689, Version 1.2020.33400 was 9.958ms
    16:06:55 Loaded Extensions - Plug-in Chip.AD9689, Version 1.2020.33400 - 14.903ms
    16:06:55 Initialization time for plug-in Chip.AD9689, Version 1.2020.33400 was 16.026ms
    16:06:55 Loaded plug-in Chip.AD9689, Version 1.2020.33400 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.AD9689.1.2020.33400 in 16.143ms
    16:06:55 Lookup time for plug-in Board.AD9689, Version 1.2020.6400 was 0.008ms
    16:06:55 Assembly registration time for plug-in Chip.ADMV1013, Version 0.1.5 was 90.725ms
    16:06:55 Loaded Extensions - Plug-in Chip.ADMV1013, Version 0.1.5 - 164.399ms
    16:06:55 Initialization time for plug-in Chip.ADMV1013, Version 0.1.5 was 191.138ms
    16:06:55 Loaded plug-in Chip.ADMV1013, Version 0.1.5 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADMV1013.0.1.5 in 191.255ms
    16:06:55 Lookup time for plug-in Board.ADMV1013, Version 1.2019.9400 was 0.007ms
    16:06:55 Thread #1, ran UI.NavigateToPath - Path = "Root::"
    16:06:55 Assembly registration time for plug-in Board.AD9689, Version 1.2020.6400 was 6.387ms
    16:06:55 Loaded Extensions - Plug-in Board.AD9689, Version 1.2020.6400 - 18.752ms
    16:06:55 Initialization time for plug-in Board.AD9689, Version 1.2020.6400 was 19.853ms
    16:06:55 Loaded plug-in Board.AD9689, Version 1.2020.6400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.AD9689.1.2020.6400 in 19.968ms
    16:06:55 Assembly registration time for plug-in Chip.ADA2200, Version 1.10.2 was 82.953ms
    16:06:55 Loaded Extensions - Plug-in Chip.ADA2200, Version 1.10.2 - 85.023ms
    16:06:55 Initialization time for plug-in Chip.ADA2200, Version 1.10.2 was 85.749ms
    16:06:55 Loaded plug-in Chip.ADA2200, Version 1.10.2 from C:\ProgramData\Analog Devices\ACE\Plugins\Chip.ADA2200.1.10.2 in 85.86ms
    16:06:55 Lookup time for plug-in Board.ADA2200, Version 1.2025.1241419 was 0.008ms
    16:06:55 Assembly registration time for plug-in Board.ADMV1013, Version 1.2019.9400 was 43.322ms
    16:06:55 Loaded Extensions - Plug-in Board.ADMV1013, Version 1.2019.9400 - 44.412ms
    16:06:55 Initialization time for plug-in Board.ADMV1013, Version 1.2019.9400 was 70.907ms
    16:06:55 Loaded plug-in Board.ADMV1013, Version 1.2019.9400 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADMV1013.1.2019.09400 in 70.998ms
    16:06:55 Lookup time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 0.007ms
    16:06:55 Finished caching XML from C:\ProgramData\Analog Devices\ACE\Plugins in 1435.274ms
    16:06:55 Assembly registration time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 7.165ms
    16:06:55 Loaded Extensions - Plug-in Board.LegacyQevModules, Version 1.2021.28300 - 7.74ms
    16:06:55 Initialization time for plug-in Board.LegacyQevModules, Version 1.2021.28300 was 32.242ms
    16:06:55 Loaded plug-in Board.LegacyQevModules, Version 1.2021.28300 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.LegacyQevModules.1.2021.28300 in 32.341ms
    16:06:55 Assembly registration time for plug-in Board.ADA2200, Version 1.2025.1241419 was 65.499ms
    16:06:55 Loaded Extensions - Plug-in Board.ADA2200, Version 1.2025.1241419 - 66.392ms
    16:06:55 Initialization time for plug-in Board.ADA2200, Version 1.2025.1241419 was 67.196ms
    16:06:55 Loaded plug-in Board.ADA2200, Version 1.2025.1241419 from C:\ProgramData\Analog Devices\ACE\Plugins\Board.ADA2200.1.2025.1241419 in 67.301ms
    16:06:56 Startup time = 1.9605085 seconds.
    16:06:56 Loaded Extensions - Plug-in Hardware.SdpSupport, Version 1.2024.34500 - 2292.792ms
    16:06:56 Initialization time for plug-in Hardware.SdpSupport, Version 1.2024.34500 was 2294.298ms
    16:06:56 Dependency Hardware.SdpSupport loaded in 2295.578ms
    16:06:56 Assembly registration time for plug-in Support.IIO, Version 1.2025.2611551 was 0.71ms
    16:06:56 Loaded Extensions - Plug-in Support.IIO, Version 1.2025.2611551 - 1.217ms
    16:06:56 Initialization time for plug-in Support.IIO, Version 1.2025.2611551 was 2308.457ms
    16:06:56 Loaded plug-in Support.IIO, Version 1.2025.2611551 from C:\ProgramData\Analog Devices\ACE\Plugins\Support.IIO.1.2025.2611551 in 2310.953ms
    16:06:56 Time to check signing for plugins 88.623ms
    16:06:56 Finished loading plugins from C:\ProgramData\Analog Devices\ACE\Plugins in 2436.555ms
    16:06:57 Details.txt file not found for drive C:\!
    16:06:59 Downloading swdownloads.analog.com/.../latest_version.ini to C:\Users\user\AppData\Local\Analog Devices\ACE\Updater\latest_version.ini using WebClient.
    16:07:44 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:08:13 Thread #1, ran UI.SelectTab - ViewId = "Root::"
    16:08:15 Details.txt file not found for drive C:\!
    16:08:37 Thread #1, ran Sessions.CreateNewSession - SkipOnExisting = False
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference dd4ffb69d2f7a4b1855c55f6f907740b3af58ca5
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference 8fc24c763c60cbe545ee2e9e76c401dc91b00ed2
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference 8d8fd58aa48c7e204cfd2a43f81d30e4e2687250
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference b975afdc5ea631feafac4bbfe2bc0163ecae11b6
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference 91879418028ab4e55919bc8ccae9d2edfe2f889a
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference e36aa52b0a6fdf00f2be47e381314bac6c086731
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference 3a2bbd52e78f2e90398d4bd72ef83950b489a8c7
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference a1c5285df055f995375f4e48d16d5450d230dcea
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference c19ac15429e7852f7f1a028db8e192055eadfe00
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference c5d3b313a3c3c229da5adec61574d8932e87319b
    16:08:37 Chip.ADF4377 yoda factory: Ignoring bad Yoda register bitfield reference bcea265120f14e3e3fb7360b7587e6fac301493e
    16:08:37 Error parsing YODA file BuildDate. Consider rebuilding .space file to ensure it was generated correctly.
    16:08:37 Thread #1, ran Hardware.UI.AddAttachedHardware - EvalBoards = ("ADF4377Board")
    16:08:37 Thread #1, ran UI.NavigateToPath - Path = "Root::System"
    16:08:38 Thread #1, ran @DefaultView -
    16:08:38 Thread #1, ran @CheckState -
    16:08:39 Thread #1, ran @CheckState -
    16:08:40 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:08:40 Thread #1, ran @CheckState -
    16:08:41 Thread #1, ran @CheckState -
    16:08:42 Thread #1, ran @CheckState -
    16:08:43 Thread #1, ran @CheckState -
    16:08:44 Thread #1, ran @CheckState -
    16:08:45 Thread #1, ran @CheckState -
    16:08:46 Thread #1, ran @CheckState -
    16:08:47 Thread #1, ran @CheckState -
    16:08:48 Thread #1, ran @CheckState -
    16:08:49 Thread #1, ran @CheckState -
    16:08:50 Thread #1, ran @CheckState -
    16:08:52 Thread #1, ran @CheckState -
    16:08:53 Thread #1, ran @CheckState -
    16:08:54 Thread #1, ran @CheckState -
    16:08:55 Thread #1, ran @CheckState -
    16:08:56 Thread #1, ran @CheckState -
    16:08:57 Thread #1, ran @CheckState -
    16:08:58 Thread #1, ran @CheckState -
    16:08:59 Thread #1, ran @CheckState -
    16:09:00 Thread #1, ran @CheckState -
    16:09:01 Thread #1, ran @CheckState -
    16:09:02 Thread #1, ran @CheckState -
    16:09:03 Thread #1, ran @CheckState -
    16:09:04 Thread #1, ran @CheckState -
    16:09:05 Thread #1, ran @CheckState -
    16:09:06 Thread #1, ran @CheckState -
    16:09:07 Thread #1, ran @CheckState -
    16:09:08 Thread #1, ran @CheckState -
    16:09:09 Thread #1, ran @CheckState -
    16:09:10 Thread #1, ran @CheckState -
    16:09:11 Thread #1, ran @CheckState -
    16:09:12 Thread #1, ran @CheckState -
    16:09:13 Thread #1, ran @CheckState -
    16:09:14 Thread #1, ran @CheckState -
    16:09:15 Thread #1, ran @CheckState -
    16:09:16 Thread #1, ran @CheckState -
    16:09:17 Thread #1, ran @CheckState -
    16:09:18 Thread #1, ran @CheckState -
    16:09:19 Thread #1, ran @CheckState -
    16:09:20 Thread #1, ran @CheckState -
    16:09:21 Thread #1, ran @CheckState -
    16:09:22 Thread #1, ran @CheckState -
    16:09:23 Thread #1, ran @CheckState -
    16:09:24 Thread #1, ran @CheckState -
    16:09:25 Thread #1, ran @CheckState -
    16:09:26 Thread #1, ran @CheckState -
    16:09:27 Thread #1, ran @CheckState -
    16:09:28 Thread #1, ran @CheckState -
    16:09:29 Thread #1, ran @CheckState -
    16:09:30 Thread #1, ran @CheckState -
    16:09:31 Thread #1, ran @CheckState -
    16:09:32 Thread #1, ran @CheckState -
    16:09:33 Thread #1, ran @CheckState -
    16:09:33 PackageProvider is refreshing the package list.
    16:09:34 Thread #1, ran @CheckState -
    16:09:35 Thread #1, ran @CheckState -
    16:09:36 Thread #1, ran @CheckState -
    16:09:37 Thread #1, ran @CheckState -
    16:09:38 Thread #1, ran @CheckState -
    16:09:39 Thread #1, ran @CheckState -
    16:09:40 Thread #1, ran @CheckState -
    16:09:41 Thread #1, ran @CheckState -
    16:09:42 Thread #1, ran @CheckState -
    16:09:43 Thread #1, ran @CheckState -
    16:09:44 Thread #1, ran @CheckState -
    16:09:45 Thread #1, ran @CheckState -
    16:09:46 Thread #1, ran @CheckState -
    16:09:47 Thread #1, ran @CheckState -
    16:09:48 Thread #1, ran @CheckState -
    16:09:49 Thread #1, ran @CheckState -
    16:09:50 Thread #1, ran @CheckState -
    16:09:51 Thread #1, ran @CheckState -
    16:09:52 Thread #1, ran @CheckState -
    16:09:53 Thread #1, ran @CheckState -
    16:09:54 Thread #1, ran @CheckState -
    16:09:55 Thread #1, ran @CheckState -
    16:09:56 Thread #1, ran @CheckState -
    16:09:57 Thread #1, ran @CheckState -
    16:09:58 Thread #1, ran @CheckState -
    16:09:59 Thread #1, ran @CheckState -
    16:10:00 Thread #1, ran @CheckState -
    16:10:01 Thread #1, ran @CheckState -
    16:10:02 Thread #1, ran @CheckState -
    16:10:03 Thread #1, ran @CheckState -
    16:10:04 Thread #1, ran @CheckState -
    16:10:05 Thread #1, ran @CheckState -
    16:10:06 Thread #1, ran @CheckState -
    16:10:07 Thread #1, ran @CheckState -
    16:10:08 Thread #1, ran @CheckState -
    16:10:09 Thread #1, ran @CheckState -
    16:10:10 Thread #1, ran @CheckState -
    16:10:11 Thread #1, ran @CheckState -
    16:10:12 Thread #1, ran @CheckState -
    16:10:13 Thread #1, ran @CheckState -
    16:10:14 Thread #1, ran @CheckState -
    16:10:15 Thread #1, ran @CheckState -
    16:10:16 Thread #1, ran @CheckState -
    16:10:17 Thread #1, ran @CheckState -
    16:10:18 Thread #1, ran @CheckState -
    16:10:19 Thread #1, ran @CheckState -
    16:10:20 Thread #1, ran @CheckState -
    16:10:21 Thread #1, ran @CheckState -
    16:10:22 Thread #1, ran @CheckState -
    16:10:23 Thread #1, ran @CheckState -
    16:10:24 Thread #1, ran @CheckState -
    16:10:25 Thread #1, ran @CheckState -
    16:10:26 Thread #1, ran @CheckState -
    16:10:27 Thread #1, ran @CheckState -
    16:10:28 Thread #1, ran @CheckState -
    16:10:29 Thread #1, ran @CheckState -
    16:10:30 Thread #1, ran @CheckState -
    16:10:31 Thread #1, ran @CheckState -
    16:10:32 Thread #1, ran @CheckState -
    16:10:33 Thread #1, ran @CheckState -
    16:10:34 Thread #1, ran @CheckState -
    16:10:35 Thread #1, ran @CheckState -
    16:10:36 Thread #1, ran @CheckState -
    16:10:37 Thread #1, ran @CheckState -
    16:10:38 Thread #1, ran @CheckState -
    16:10:39 Thread #1, ran @CheckState -
    16:10:40 PackageProvider is refreshing the package list.
    16:10:40 Thread #1, ran @CheckState -
    16:10:41 Thread #1, ran @CheckState -
    16:10:42 Thread #1, ran @CheckState -
    16:10:43 Thread #1, ran @CheckState -
    16:10:44 Thread #1, ran @CheckState -
    16:10:44 Thread #1, ran UI.SelectTab - ViewId = "Root::"
    16:10:47 Details.txt file not found for drive C:\!
    16:11:03 Thread #1, ran UI.SelectTab - ViewId = "Root::System"
    16:11:07 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.ADF4377 Board"
    16:11:07 Thread #1, ran UI.CloseTab - ViewId = "Root::System"
    16:11:07 Thread #1, ran @CheckState -
    16:11:08 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:11:08 Thread #1, ran @CheckState -
    16:11:09 Thread #1, ran @CheckState -
    16:11:10 Thread #1, ran @CheckState -
    16:11:11 Thread #1, ran @CheckState -
    16:11:12 Thread #1, ran @CheckState -
    16:11:13 Thread #1, ran @CheckState -
    16:11:14 Thread #1, ran @CheckState -
    16:11:15 Thread #1, ran @CheckState -
    16:11:16 Thread #1, ran @CheckState -
    16:11:17 Thread #1, ran @CheckState -
    16:11:18 Thread #1, ran @CheckState -
    16:11:19 Thread #1, ran @CheckState -
    16:11:20 Thread #1, ran @CheckState -
    16:11:21 Thread #1, ran @CheckState -
    16:11:22 Thread #1, ran @CheckState -
    16:11:23 Thread #1, ran @CheckState -
    16:11:24 Thread #1, ran @CheckState -
    16:11:25 Thread #1, ran @CheckState -
    16:11:26 Thread #1, ran @CheckState -
    16:11:27 Thread #1, ran @CheckState -
    16:11:28 Thread #1, ran @CheckState -
    16:11:29 Thread #1, ran @CheckState -
    16:11:30 Thread #1, ran @CheckState -
    16:11:31 Thread #1, ran @CheckState -
    16:11:32 Thread #1, ran @CheckState -
    16:11:33 Thread #1, ran @CheckState -
    16:11:34 Thread #1, ran @CheckState -
    16:11:35 Thread #1, ran @CheckState -
    16:11:36 Thread #1, ran @CheckState -
    16:11:37 Thread #1, ran @CheckState -
    16:11:38 Thread #1, ran @CheckState -
    16:11:39 Thread #1, ran @CheckState -
    16:11:40 Thread #1, ran @CheckState -
    16:11:41 Thread #1, ran @CheckState -
    16:11:42 Thread #1, ran @CheckState -
    16:11:43 Thread #1, ran @CheckState -
    16:11:44 Thread #1, ran @CheckState -
    16:11:45 Thread #1, ran @CheckState -
    16:11:46 Thread #1, ran @CheckState -
    16:11:47 Thread #1, ran @CheckState -
    16:11:48 Thread #1, ran @CheckState -
    16:11:49 Thread #1, ran @CheckState -
    16:11:50 Thread #1, ran @CheckState -
    16:11:51 Thread #1, ran @CheckState -
    16:11:52 Thread #1, ran @CheckState -
    16:11:53 Thread #1, ran @CheckState -
    16:11:54 Thread #1, ran @CheckState -
    16:11:55 Thread #1, ran @CheckState -
    16:11:56 Thread #1, ran @CheckState -
    16:11:57 Thread #1, ran @CheckState -
    16:11:58 Thread #1, ran @CheckState -
    16:11:59 Thread #1, ran @CheckState -
    16:12:00 Thread #1, ran @CheckState -
    16:12:01 Thread #1, ran @CheckState -
    16:12:02 Thread #1, ran @CheckState -
    16:12:03 Thread #1, ran @CheckState -
    16:12:04 Thread #1, ran @CheckState -
    16:12:05 Thread #1, ran @CheckState -
    16:12:06 Thread #1, ran @CheckState -
    16:12:07 Thread #1, ran @CheckState -
    16:12:08 Thread #1, ran @CheckState -
    16:12:09 Thread #1, ran @CheckState -
    16:12:10 Thread #1, ran @CheckState -
    16:12:11 Thread #1, ran @CheckState -
    16:12:12 Thread #1, ran @CheckState -
    16:12:13 Thread #1, ran @CheckState -
    16:12:14 Thread #1, ran @CheckState -
    16:12:15 Thread #1, ran @CheckState -
    16:12:16 Thread #1, ran @CheckState -
    16:12:17 Thread #1, ran @CheckState -
    16:12:18 Thread #1, ran @CheckState -
    16:12:19 Thread #1, ran @CheckState -
    16:12:20 Thread #1, ran @CheckState -
    16:12:21 Thread #1, ran @CheckState -
    16:12:22 Thread #1, ran @CheckState -
    16:12:23 Thread #1, ran @CheckState -
    16:12:24 Thread #1, ran @CheckState -
    16:12:25 Thread #1, ran @CheckState -
    16:12:26 Thread #1, ran UI.SelectTab - ViewId = "Root::"
    16:12:27 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:12:28 Thread #1, ran UI.SelectTab - ViewId = "Root::System.Subsystem_1.ADF4377 Board"
    16:12:29 Thread #1, ran @CheckState -
    16:12:30 Thread #1, ran @CheckState -
    16:12:31 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:12:31 Thread #1, ran UI.CloseTab - ViewId = "Root::System.Subsystem_1.ADF4377 Board"
    16:12:31 Thread #1, ran @CheckState -
    16:12:32 Thread #1, ran @CheckState -
    16:12:33 Thread #1, ran UI.SelectTab - ViewId = "Root::"
    16:12:35 Details.txt file not found for drive C:\!
    16:12:38 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:15:39 PackageProvider is refreshing the package list.
    16:15:40 Thread #1, ran UI.SelectTab - ViewId = "Root::"
    16:15:44 Details.txt file not found for drive C:\!
    16:15:54 Thread #1, ran UI.ManuallyAddSubsystem -
    16:16:05 Thread #1, ran UI.SelectTab - ViewId = "tool.pluginmanager"
    16:16:22 PackageProvider is refreshing the package list.
    16:16:23 PackageProvider is refreshing the package list.
    16:16:27 PackageProvider is refreshing the package list.
    16:16:59 Downloading swdownloads.analog.com/.../latest_version.ini to C:\Users\user\AppData\Local\Analog Devices\ACE\Updater\latest_version.ini using WebClient.
    I would appreciate a quick reply
  • Hi  ,
    Thanks for sending on the log file,
    Could you clarify what you meant by "working"? Is it that the power supply is working or that the board is working in ACE?
    On the log file, I cannot see any indication of the device being connected, can you verify that you saw the "No daughterboards detected" tile when this log file was recorded?
    If the 120-pin connector is seated correctly and the power supply is connected, it is quite unusual that the evaluation board is not connecting.
    There are some LEDs on the board, labelled DS1-DS5. Could you observe these after connecting the board to USB/power supply and check if any lights are showing on these? This would help to indicate whether the board is powering up.
    Thanks
    Eoin
  • Hi
    1.The connection here is the long 120-pin white connector, please ensure that this is fully seated and there is no dust or debris in the connector socket. I checked
    2. I also note that the EV-ADF4377SD1Z eval board requires a 6V external supply, provided to either the banana plug connectors or SMA connector.  I checked
    Please ensure that your power supply is connected and that the polarity is correct, this is required to power the evaluation board for communication with ACE. this is polarity is correct
    There are some LEDs on the board, labelled DS1-DS5. Could you observe these after connecting the board to USB/power supply and check if any lights are showing on these? This would help to indicate whether the board is powering up. yes
    have 4 LED on evb adf4377 that lights
    have one LED on sdp-s that lights
    Thanks
    Yaniv
  • Hi
    I have more information.
    Attached is a picture of ACE status with board connection
    Maybe you have remote support for customers?
    The project is just very stressful
    Thanks
    Yaniv
  •  Hi  ,
    We've moved this thread to the RF forum where the product team can assist you directly.
      could you please follow up with the customer on this.
    From the information provided, we suspect that the eval board either has a blank or corrupted EEPROM, due to SDP-S controller board appearing, LEDs on eval board indicating it is powered correctly and ACE showing "No Daughterboard Detected". It is also possible that there are issues with the I2C line used to communicate with the EEPROM.
    Thanks
    Eoin
    You can recover the EEPROM on the eval board. On the left side of the ACE GUI, there is EEPROM Recovery under the Tools section.
    The EEPROM Address is 0x52.
    The attached thread contains a download link for EEPROM Content. Also, it includes steps to bypass the EEPROM reading.
    (1) ADF4368 - Q&A - RF and Microwave - EngineerZone
    Emrecan
