PFD frecuency
Product Number: EV-ADF4159EB3Z
Hello, I want to generate a sawtooth output using the EV-ADF4159EB3Z board, connecting an external VCO operating from 1200–2300 MHz, specifically the CVCO55BE-1200-2300.
The board includes a 100 MHz reference oscillator. In ADIsimPLL, I’m not able to select a divider to reach the operating frequencies I need (I used 50 MHz directly), although in the board’s control software I can do it.
Is this actually the case? Can I use the EV-ADF4159EB3Z to generate frequencies within the 1200–2300 MHz range?
Attached are some images to better illustrate the case.
    In the ADISimPLL, you need to set the PFD frequency on the PLL Configuration.
    Click File --> PLL Configurations,
    Then, on this screen, set the PFD frequency and reference frequency.
    Please note that since you are modifying the PFD frequency and using a different VCO that loop filter is desinged for, you need to simulate the loop filter with your VCO and PFD settings then implement it to the evaluation board.
    Emrecan
  • Yes, I simulated exactly as you said, but I wanted to know if it’s really possible to set 50 MHz and then use the divide-by-2 to get that phase detector frequency. I ran simulations with those settings—using the chosen VCO and the loop filter—and obtained the expected results.
    I just wanted to confirm whether it’s possible to use the 100 MHz reference and set the phase detector to 50 MHz.
    Andrés.
