3D STEP FILE
The user requested a 3D Step file for the EVAL-AD8302-ARDZ evaluation board to assist with mechanical alignment. The final answer stated that Analog Devices does not provide 3D Step files for evaluation boards, as they are not intended for precise mechanical integration. The user was advised against integrating the evaluation board into a fixture.
Product Number: EVAL-AD8302-ARDZ, AD8302
Dear Team,
I am looking for the 3D Step file of the EVAL-AD8302-ARDZ  to help our mechanical team plan the board alignment along with other boards in our setup.
It would be greatly appreciated if you could share the 3D Step file at the earliest.
Kind regards,
Athira K
  • We do not provide step files for our evaluation boards. They are intended for lab evaluation of a device. As a result, their precise mechanical dimensions should not be critical. It sounds like to are planning to integrate the AD8302 evaluation into a fixture. If you are doing this, we would strongly advise agains this because  you are not using the evaluation board as it is intended.
