I am looking at using HMC3587LP3BE as a LO buffer amplifier. In the datasheet, there is no data available for phase noise. Is it possible to provide measurement phase noise data at 8GHz and 10GHz?
Thank you.
Strong EMC design
HMC3587
Recommended for New Designs
The HMC3587LP 3BE is a HBT Gain Block MMI C amplifier covering 4 GHz to 10 GHz and packaged in a 3×3 mm plastic QFN SM T package. This versatile amplifier...
Datasheet
HMC3587 on Analog.com
Thank you.
There is a plot in the datasheet showing residual phase noise at 5 GHz and 7 GHz. The input power level is 0 dBm which would put the output power roughly midway between compression and saturation. We do not have data at other power levels or frequencies.
Note that there are some newer devices available. Take a look at ADL8150. You can see other options here.
Many thanks for replying. I got some questions on the plot. There are some spurs from 10Hz to about 100Hz offset. Do you what is this due to? At 100Hz, difficult to guage the phase noise. Is that -110dBc/Hz? Does the amplifier usually dominate phase noise upto 1/f flicker (100kHz)? Thank you
Hello
Regarding HMC3586LP3BE, is it recommended to connect all NC Pins (1, 3, 4, 5,
6, 7, 9, 11) to the GND layer.
Do you need any other assistance or can I close out this case?
Thank you very much for the assistance. Please close the case.
In relation to your last query, yes the ambient temperature is higher than 85C.
Hello enash
Thank you for helping me. After doing the lineup analysis, I need an amplifier which have higher gain than HMC3587LP3BE. The gain of HMC3587 is about 14.6dB in C band. I need an amplifier which have about 18 to 19dB gain to drive LO port of LTC5549 of 0dB typ. Can you please recommend and with similar phase noise? Thank you.
The chain is 2dB pad, AMP, 2dB+3dB bandpass+2dB pad+3.5dB Splitter.
The power from the DAC is -6dBm.
