ADRF5720: About operation at abnormal condition
The user inquires about the ADRF5720's behavior under abnormal power conditions. The final answer advises: 1) Power up VSS after VDD to avoid damage from current transients. 2) Power down VSS before VDD. 3) Control voltage can be applied after VDD but before VSS. No URLs or additional clarifications are necessary.
Product Number: ADRF5720
Our customer is minding to use ADRF5720 at abnormal condition.
So, their condition is below.
1. In power up, if VSS is input firster than VDD, will ADRF5720 be broken?
2. In power down, if VDD is pulled down firster than VSS, will ADRF5720 be broken?
3. In only input VDD, if the control voltage is input, will ADRF5720 be broken?
Could you give me any answer and advice?
Best Regards,
Tomohiro
  • Q1. In power up, if VSS is input firster than VDD, will ADRF5720 be broken?
    A1. Datasheet says "Power up VSS after
    VDD to avoid current transients on VDD during ramp-up". This could damage the part over time so I would set things to prevent VSS turning on first.
    Q2. In power down, if VDD is pulled down firster than VSS, will ADRF5720 be broken?
    A2. The datasheet recommendation is "The power-down sequence is the reverse order of the power-up
    sequence". So VSS shoudl turn off before VDD.
    Q3. In only input VDD, if the control voltage is input, will ADRF5720 be broken?
    A3. The digital inputs can be applied after VDD has turned on and before VSS has turned on.
  • Hi Eamon-san,
    Thank you for prompt answer.
    I understood and will describe to the customer.
    Best Regards,
    Tomohiro
