How do I use an external ADC with the MAX2771?
The user is configuring the MAX2771 GNSS receiver to use an external ADC (LTC2268-14) for higher dynamic range. The final answer recommends treating the ANAIPOUT and ANAINOUT pins like the I0, I1, Q0, and Q1 output pins, keeping the load lighter than 10kΩ||7.5pF, and suggests adding an ADC driver amplifier if necessary, depending on the ADC configuration and input frequency.
Product Number: MAX2771
Good day,
I'm working with a MAX2771 GNSS receiver and want to use an external ADC for higher dynamic range. The MAX2771 datasheet states that it has an analog output of the I-arm for continuous spectrum monitoring, which I'd like to use for this. I can see in the datasheet how setting bit 28 of the Configuration 2 Register enables this analog output, but I haven't found any information on the output port characteristics.
The ADC I want to use for this is the LTC2268-14, a dual channel 125 MSPS 14 bit ADC (the other channel would be connected to another MAX2771). What do I need to consider regarding matching and IF amplification of the analog output of the MAX2771?
  • I recommend that you treat the ANAIPOUT and ANAINOUT pins the same as the I0, I1, Q0 and Q1 output pins when they are configured for ADC bypass, that is keep the load lighter than 10kΩ||7.5pF.  The datasheet is vague but I believe that there is no amplification after the baseband VGA. That means that the levels on the Aux out pins will be the same as the the levels on the I0, I1, Q0 and Q1 outputs (when the ADC is bypassed).
    It may be prudent to add an ADC driver amplifier in front of the LTC2268-1, depending on how you want to configure the ADC and what frequency you will be going in at. - Eamon
