ADF4159 AUX Power
The user inquires about using ADF5901 and ADF4159 in single-ended mode, specifically whether the -5 dBm output of ADF5901 meets the -10 dBm minimum input requirement of ADF4159. The support engineer confirms that the -10 dBm minimum input is for single-ended configuration, and the -5 dBm output is sufficient. It is recommended to follow the reference design on the EVAL-RADAR-MMIC evaluation board.
Product Number: ADF4159
If I intend to design an FMCW radar using ADF5901 and ADF4159, and I only want to use the AUX and RFINA in single-ended mode for connection, is this feasible? In this case, should the corresponding complementary AUX be left floating, and RFINB be grounded through a capacitor? Additionally, the datasheet of ADF5901 indicates that its AUX single-ended output is typically -5 dBm. However, for ADF4159, the minimum input of RFIN is -10 dBm, and it is not specified whether this is for single-ended input. Therefore, I would like to confirm whether the -10 dBm here refers to the minimum value for single-ended input; if so, the single-ended output of -5 dBm would meet the requirement.
    Yes, minimum value is defined in single ended configuration. You can use ADF4159 and ADF5901 in single ended configurations. However, we recommend following recommended reference design given in the EVAL-RADAR-MMIC evaluation board.
    Emrecan
  • Thank you very much for your reply. Let me explain the situation. Actually, I intend to use a non-chip with the ADF4159 for FMCW radar design. Since this chip comes in a BGA package, it is not easy to route one of the pins of the DIV internally. Therefore, I want to connect it to the ADF4159 in a single-ended manner, which is why I consulted the similar case of the 5901 and the 4159.
    The single-ended output of this new chip is -6dBm, so I would like to confirm whether the minimum input of the ADF4159 is single-ended. Based on your explanation, such a connection should be correct. The single-ended output of the 5901 is -5dBm, which is similar to that of my new chip, and both fall within the -10dBm requirement for the single-ended input of the ADF4159. The other end of the ADF4159 is connected to GND via a capacitor.
  • Yes, minimum value is defined in single ended configuration. You can use ADF4159 and ADF5901 in single ended configurations. However, we recommend following recommended reference design given in the EVAL-RADAR-MMIC evaluation board.
    can you help me with my real situation? Thanks!
