I’m currently designing a biasing circuit for the HMC943APM5E and have a couple of questions regarding gate current (Ig), which I couldn’t find specified in the datasheet.
Gate Current Information Missing?
The datasheet doesn’t specify the gate current (Ig), which is typically necessary for properly designing a bias circuit. My current biasing circuit is capable of handling up to 300 mA for Gate current Ig.
Is this sufficient?
Does the absence of Ig in the datasheet imply that it is negligible or doesn't matter ?
Am I misunderstanding something in terms of how Ig should factor into the design for this device?
Gate Current Control Without Performance Impact
Assuming Ig is non-negligible, is there a recommended method to limit or control gate current without degrading the amplifier's performance? For example, would using a series resistor or current limiter on the gate line negatively impact stability or linearity?
I’d appreciate any clarification or design recommendations based on experience with this part.
