Can the LTC5553 support RF frequencies as low as 500 MHz?
The user is using the LTC5553 to down-convert RF signals from 500 MHz to 10 GHz to a 1.5 GHz IF. The final answer indicates that the device's performance degrades below 3 GHz, with increased conversion loss and worse RF input return loss, making it unusable over the full frequency range. The datasheet plots on pages 5 and 10 show this degradation.
View FAQ
Hi Team,
I’m using the LTC5553 to down-convert RF signals to a 1.5 GHz IF, but the RF input spans from 500 MHz to 10 GHz. The datasheet specifies that the RF port is well-matched only from 3 to 20 GHz. Can you clarify what happens between 500 and 3000 MHz?
Thankyou
Thread Notes
