Does the AD8366-EVALZ support the devices serial mode? From the schematic it looks to me that pins BIT0/CS and BIT1/SDAT can only be connect to GND or VPOS via switches?
AD8366
Recommended for New Designs
The AD8366 is a matched pair of fully differential, low noise and low distortion, digitally programmable variable gain amplifiers (VGAs). The gain of each...
Datasheet
AD8366 on Analog.com
AD8336
Production
The AD8336 is a low noise, single-ended, linear in dB, general-purpose variable gain amplifier, usable over a large range of supply voltages. It features...
Datasheet
AD8336 on Analog.com
GLADION - Moved from Variable Gain Amplifiers (VGA) to RF and Microwave. Post date updated from Tuesday, June 10, 2025 9:25 AM UTC to Friday, June 13, 2025 12:14 AM UTC to reflect the move.
Hi David,
I will check into your question and will get back to you as soon as possible.
Best Regards
Eamon
Hi David,
the evaluation board supports parallel and serial mode operation. It appears that the eval board schematic is incorrect or at least incomplete as it does not include the digital header.
AD8366 is an old part. While it is still in full production, it you are starting a new design, I think that there are better parts that we can recommend. If you can give me some guidance on your needs and target specs (e.g. gain range, operating frequency, with/without programmable filtering, etc), I can recommend some better alternatives.
Best Regards
Eamon
Hi Eamon,
I will come back to you regarding requirements.
In the meantime;
1. is it necessary to only transmit 12 bits in serial mode or can 16 bits be transmitted with the gain data in bits 11:0?
2. what is the state after power reset of the AD8366, i.e., what is the gain after reset?
Best,
David
PS: Who is Pedro?
Hi David,
my apologies. I mixed up your name with another customer. I think that you need to write exactly 12 bits when programming in serial mode. If you write 12 bits and 4 dummy bits for a total of 16 bits, I think that your data may get lost.
I'm not able to find out the power on reset status of this part because it is very old. But I believe that we have a board in the lab to test this on. Please give me a day or two to work on this.
Best Regards
Eamon
Hi Dave,
one of my colleagues set this up and verified that the part turns on at minimum gain.
Best Regards
Eamon
Hi again Dave,
we ran a few other tests for completeness and discovered the following.
Thanks for elaborating on this.
Regarding 12bit- vs. 16-bit transfers:
The serial interface is most likely implemented as a shift register latching the gain words at the rising edge of BIT0/CS.
If that is the case, clocking in LEADING zeros should be fine, i.e., the following 2 transfers should have the same effect:
12 bit: [CS H->L], B0, ..., B5, A0, ..., A5, [CS L->H]
16 bit: [CS H->L], 0, 0, 0, 0, B0, ..., B5, A0, ..., A5. [CS L->H].
Could you test this?
Thanks and BR,
David
Hi David,
to your question about a 12-bit write vs a 16-bit write with four leading 0s, I tend to agree with you that the four leading 0s will just get clocked through the part and disappear. I need to think about how we can check this on the bench. We don't have a multi-channel logic generator on hand. I believe that we could “bit-bang” the sequence using the on-board DIP switches. My colleague did however mention that he found the setup a bit glitchy when he was doing the power-on testing. I'll talk to him and see what can be done.
Best Regards
Eamon
Hi again David,
we tried to do a 16-bit write to the device on the bench using with DIP switches on the evaluation board, that is, by manually flipping the clock and data signals up and down. As feared, there was too much glitchiness in the system and we were not able to get anything to work (i.e. neither a 12 bit write or a 16 bit write would work). So the result is that we cannot easily verify this on the bench (we also don't have a pattern generator on hand). Is this something you can verify on your side?
Eamon
Hi Eamon,
I will try to. I am pretty sure already shifting leading zeros doesn't work - but I have to double check.
Also if it indeed doesn't work I will implement a custom SPI adapter and see if things work then.
In any case I will come back to you.
Thanks!
