ADL8143 overdrive recovery time
The user asked about the overdrive recovery time of the ADL8143 when a 15dBm 12GHz signal is present at the RFIN pin and the RBIAS pin is disabled, then enabled. The final answer indicates that the overdrive recovery time is approximately 30us, similar for both enable and disable operations. The user inquired about methods to reduce this timing, but no specific solutions were provided in the thread.
Category: Datasheet/Specs
Product Number: ADL8143
On datasheet Figure 45, an overdrive recovery time of 30us is expected when a 15dBm 12GHz signal is present at RFIN pin.
If ADL8143 is disabled at RBIAS pin and a 15dBm 12GHz signal is present at RFIN pin, what is the overdrive recovery time after the 15dBm 12GHz signal is removed at RFIN pin and RBIAS pin is enabled? Thanks.
