Datasheet Test Results derived From the MMIC EVB?
Product Number: HMC260ALC3B
Hi
How the datasheet results were measured? Did they measure it on the EVB?
I ask this because the EVB has a big pad on the IF port that might not suite for the high IF frequencies.
We want to understand if it a must or maybe we could cut a bit the output pad such that it will not have a lot of capacitance that can lead to not optimal measurements results at high IF frequencies?
thanks
Arye
  • Hi Ari, I'm not sure what is going with that large piece of metal at the IF terminal of the board. I'll check into this and will get back to you. - Eamon
  • Hi Arye,
    I believe that this stub on the evaluation board was a mistake which was deemed to not have a significant impact on performance. For these products, the customer evaluation board also doubles as the board which is used to characterize the device and generate the datasheet plots. I also discovered that this same bare board is used as the evaluation board for multiple other RF mixers that are pin-compatible (e.g. HMC260, HMC292, HMC, 329, etc).
    I could see no references in the datasets to the IF port trace loss or return loss being de-embedded (the s-parameter file says that the measurement is referenced to the connectors.
    I did find de-embedded and non-de-embedded return loss s-parameters for the IF port of the HMC260LC3B, an earlier revision of the part which used the same evaluation board. Those data showed that the de-embedded return loss improved when the IF trace and stub were calibrated away. So all of this points to the stub being a mistake and not deliberate.
    My recommendation to you therefore would be to do a straight-up 50 ohm trace line into the RF port. Please let me know if you have any other questions.
    Best Regards
    Eamon
  • thanks a lot.
    i think we will try to cut manually the pad and see if the S11 gets better at higher freqs
