If I want to input a reset signal to initialize the ADF4377, is there a guideline for how long I need to input "L" to CE?
ADF4377
Recommended for New Designs
integer-N phased locked loop (PLL) with an integrated voltage controlled oscillator (VCO) ideally suited for data converter and mixed signal front end...
Datasheet
ADF4377 on Analog.com
Setting the CE pin LOW is an asynchronous reset in digital that doesn't need a significant pulse width, but I have never checked.
I'll investigate internally and reply to you as soon as possible.
Emrecan
I found out that bringing CE low:
Therefore, we recommend minimum of 100us low pulse at the CE pin to reset the part.
Emrecan
