Hello Team,
We are looking for the ADTR1107 System Vue modeling data.
Could you please support this data?
ADAR1000 is being used together.
Thank you
Best and Regards,
Josh.
ADTR1107
Recommended for New Designs
The ADTR1107 is a compact, 6 GHz to 18 GHz, front-end ICÂ with an integrated power amplifier, low noise amplifier (LNA), and a reflective single-pole double...
Datasheet
ADTR1107 on Analog.com
ADAR1000
The ADAR1000 is a 4-channel, X and Ku frequency band, beamforming core chip for phased arrays. This device operates in half-duplex between receive and...
Datasheet
ADAR1000 on Analog.com
Hello Team,
Thank you
Best and Regards,
Josh.
Hello team,
I haven't received a reply yet.
Could you please support my quest?
Thank you.
Best & Regards,
Josh
Hi Josh, there is model data for ADTR1107 Tx and Rx in the ADI Library in SystemVue. If you don't have the most up to date library, you can download it at www.analog.com/sys-parameters. Note that these are frequency domain models. You cannot simulate stuff like switching time. Joel will be in touch about getting you the ADAR1000 model if he has not done so already.
Eamon
Hi Enash,
Thank you for your kind support.
Josh
Hi Eamon,
I have not yet receive the ADAR1000 System Vue modeling data from Joel.
Could you help me?
Thank you.
Josh
