ADPA9002 giving wrong output
Product Number: ADPA9002
     I am testing ADPA9002 evaluation board, the input given is AC coupled 1Vpp 20MHz square wave, the output i get periodic noise of about 20mV with same frequency as input.
Regards and thanks in advance
  • Hey  ,
    Can you provide more details on your test setup? Specifically, are you pulsing RFIN or VDD? Are you operating the device in self-biased mode, or are you using the alternative power-up sequence for ACG#? Also, have you incorporated a bias tee and external blocking capacitors in your setup?
    Dorant
