I have chosen this IC to design a VCO, where the output frequency will be fixed at either 200 MHz or 300 MHz (one of these two).
I have attached the schematic. Could someone check and verify whether it will work as expected? Additionally, please provide the equations to calculate the values of L1, R5, R17, C17,C18, C2, and C19. If you have direct value recommendations, that would also be helpful.
Since my PCB is very small, I cannot use a PLL. Instead, I plan to supply a fixed voltage to the VTUNE pin using a Zener diode. Please suggest whether this approach will work or if any modifications are needed.
Thank you!
