ADF5902 can not output singal
Product Number: ADF5902
The register configuration sequence in the period manual was configured and no output was found. Measuring the Vtune can see the waveform of the sawtooth.And I modify the value of register 5,tune oFF ramp,measuring the Vtune can see a fixed voltage,and it sitll cant output a fixed signal. why?
In the datasheet I found this"When programming the registers for a ramp, write the registersin descending order. Then write to Register R5 to enable theramp (Register R5, Bit DB29 = 1) must be last." but in the"Table 7. Initialization Sequence" the register 11 is the last one .so what is the correct  register configuration sequence?
