We had the following queries regarding the AD8309/AD8310 :
a. We are expecting a Log output from the limiter pins for a carrier modulated with a triangular waveform. However, we are able to see it only at the VLOG output, but not at the limiter output, with no output being seen at the limiter. Could you please point out the reason for this ? We tried for different values of Rlim and without the Rlim as well. Our understanding is that the Vlog output should give a DC output corresponding to the input Power for RSSI measurements and the limiter output should be the output waveform as shown below.
b. The same was seen at the output of AD8310 as well, and our understanding is the output should behave the same way as expected of the log output for AD8309 .
Please correct our understanding
With Regards,
ARK
