May i ask what is the Failure rate (FIT) for HMC1040LP3CE and is it prone to hydrogen poisoning?
Thank you!
HMC1040LP3CE
Production
The HMC1040LP3CE is a self-biased GaAs MMIC Low Noise Amplifier housed in a leadless 3x3 mm plastic surface mount package. The amplifier operates between...
Datasheet
HMC1040LP3CE on Analog.com
Thank you!
Hi Tryingtofindans,
Regarding hydrogen poisoning. The HMC1040 is a GaAs pHEMT device and if enclosed in a poorly ventilated or hermetically sealed enclosure would be at risk for hydrogen poisoning.
The above FIT is calculated with a die use junction temperature of 85 C. 60% & 90% confidence levels.
regards,
Jim B
Hi Tryingtofindans,
regards,
Jim B
