HMC856 input interfacing
Product Number: HMC856
Hello
we are interfacing the output of a CML fanout buffer (NB7L1008MMNR4G) with the input of HMC856 , powered between GND and -3.3V
Here below the architectures of the 2 devices
https://www.onsemi.com/download/data-sheet/pdf/nb7l1008m-d.pdf
As suggested by ONSemi app note and from one of Forum posts ( About connection of HMC 856) we initially used a DC coupled connection, relying on the 50ohm internal terminations to GND of HMC856, but the Signal Integrity at receiver was completely bad
Then we moved to AC coupling as suggested by OnSemi app note, but also in this case signal quality at receives is bad
https://www.onsemi.com/pub/Collateral/AND8173-D.PDF
We then added 50 ohm terminations at transmitter , followed by AC coupling caps at receiver, and this is at the moment the best of the configurations, but still vith very poor signal integrity at receiver
Could you please suggest the optimal termination and coupling for interfacing this driver?
Also, using positive supplies for HMC856 would simplify the power architecture for our already limited space: reading other forum's post it seems possible to power it from between +3.3V and GND, but there are no clear guidelines for that:
Can you please detail the pin connections in case of powering from positive supply?
Thanks
Alberto
  • Hi Alberto,
    Sorry for the delayed response. For HMC856, as long as a good 50ohm interface is present, DC or AC coupling are not expected to make any difference. You have to make sure your inter-connect PCB traces are 50ohm single ended or 100ohm diff.
    Do you know the output return loss of the OnSemi driver?
    Up to which frequency or Gbps are you driving the part?
    Any eye-diagram screenshots? What is your test signal(PRBS?)
    Lastly, it is possible to shift all supply and control pin voltages by 3.3V so that the part could be used with GND and +3.3V. The part would operate when there is a 3.3V difference between high and low supply rails. The AMR table of the datasheet was generated with for -3.3V supply but you may still refer to that table by shifting all limits by +3.3V.
    HMC856’s high speed input output pins are referred to the high supply rail with an internal 50ohms. If the interfacing component’s high supply rail is the same with HMC856, no DC block would be required. Otherwise, high speed pins would require DC block.
    High speed I/O pins have adjacent ground pins for proper transition from PCB to the IC. When supplies are shifted, you would need bypass capacitors to the PCB’s RF ground for pins 1,4,21,24 because they are not connected to PCB ground (0V DC) anymore. These additional capacitors prevent signal integrity issues and helps the part to work as close as possible to the datasheet performance.
