hmc1049 biasing
Category: Datasheet/Specs
Product Number: HMC1049LP5E
Does the HMC1049 need to be biased sequentially? There are several posts about using an active bias controller, however there is no requirement stated on the data sheet for bias sequencing. Will the part be damaged if the gate and drain are turned on simultaneously?
