LT5537 behavior @10.7MHz
The user is designing a matching network for the LT5537 at 10.7MHz and requested the S11/impedance data. The support engineer provided the input impedance model as a 1.94K resistor in parallel with a 2.59pF capacitor at 11MHz. The user also sought clarification on the 240Ω termination resistor used in the datasheet example at 200MHz, questioning its effectiveness in achieving maximum power transfer.
Category: Datasheet/Specs
Product Number: LT5537
Hello support team,
I am trying to design a matching network for the LT5537 from input of 330 ohm at 10.7MHz.
Can you please provide data of its S11/impedance around this frequency?
My intention is to use its differential input in order to get maximum sensitivity.
Thanks!
  • Hi RoyKV,
    At 11MHz, the LT5537's input impedance can be modeled as a 1.94K resistor in parallel with a 2.59pF capacitor.
  • Thanks,
    I found it difficult to understand the example made in the datasheet on page 9, when a termination resistor of 240Ω was connected in parallel to the AC coupled input of the LT5537 (figure 5).
    I understand the purpose of this resistor (matching the input impedance of the IC to the balun output of 200Ω for maximal power transfer).
    Here are my problems:
    1. Maximum power transfer requires that the load impedance is the complex conjugated of the source impedance. So in our case we need minimal imaginary part of the input impedance.
    2. I calculated that for 200MHz (the example frequency), the input impedance of the termination (neglecting C1 & C2) and the IC input is 2*(240Ω/2 || (1.73KΩ||1/(j*2*π*200MHz*1.45pF)) ~ 214Ω -j44Ω, so it is quite far from the expected 200Ω real part of the impedance. Thus a smaller termination resistor could have made a better job.
    What mistakes did I do?
