Bleed current vs ramp generation
Category: Datasheet/Specs
Product Number: ADF4169
Hi
I need to generate ramp (fast ramp) with quite demanding requirements. Due to the ADsim simulation results, I need about 2MHz PLL filter band. With that band, bleed current is must be for single freq with integer mode.
I wonder, if "bleed current' is working during ramp generation and how it impact on the ramp?
The PLL filter may be design with almost the same parameters, but with different CP currents? I wonder, if there are any suggestion, that I should use high or low CP current with my design
I found one application note (AN-1154) about bleed current, but there is no info about ramp generation. Do you have any other papers?
Any suggestions?
  • Hi Roman,
    Bleed current is useful when the sigma-delta modulator (SDM) is active for fractional N divider operation. It provides a constant current to the charge pump and helps to improve spurious performance.
    The Datasheet provides bleed current calculations for optimum spurious performance at a certain frequency. However, smaller or larger bleed currents also provide improvement for SDM spurs. e
    Ramp generation uses SDM to generate high-resolution ramps. Therefore we recommend using Bleed current to improve the SDM spurs.  I recommend selecting a middle point of the ramp frequency and then calculating the bleed current based on this frequency.
    Emrecan
