LTC5596 output ripple at low frequencie
Product Number: LTC5596
when running a detailed characterization of the LTC5596 power detector, I measure a strange behavior at certain frequencies.
I observe the following two phenomena (see attached images):
1. At ~ 397MHz and from 780MHz - 810MHz there is a strong ripple in the response of the detector.
2. In the region around these frequencies there is a large oscillation in the output voltage of the detector at distinct frequencies
The amplitude of the oscillation can be reduced by increasing the value of C_FLTR to the maximum specified value of 1nF. In my setup, I perform subsequent RC filtering and voltage doubling with a buffer amplifier. The input power is -5dBm. The signal generator is well matched using a 20dB attenuator.
Is there a way to resolve these issues?
