PA_BIAS Voltage not turning up
Product Number: ADAR1000
Hi team,
TX Mode for PA_BIAS configuration in SPI_TR Mode
In ADAR1000-Eval kit (REV B), after writing the foll: registers in Manual register tab of GUI
0x0081
0x0018
0x40055
0x3860
0x2f7f
0x362d
0x3706
0x3142
0x1cff
0x2036
0x2135
0x2802
0x31da
0x3040
0x2985
0x2a85
0x2b85
0x2c85
0x31da
we got foll: measurements in P9A connector
Channel  Pin Voltage
PA_BIAS1 23 0V
PA_BIAS2 17 -5V
PA_BIAS3 11 0V
PA_BIAS4 5 0v
But as per datasheet we are supposed to obtain -1.1V for 0x85 value.
We are also not able to get the exact CREG values as mentioned in datasheet :
Pin Voltage(As per datasheet) Observed voltage
CREG1 1.8V 0V
CREG2 2.8V 2.7V
CREG3 2.8V 2.7V
CREG4 1.8V 1.7V
Kindly let us know if any software changes to be taken care while doing this
Parents
  • The SPI writes look correct for what you want to do.  Can you confirm:
    • Board revision is Rev. B?
      • Rev. B is fairly old.  Has this been in your possession for a while?
    • Re-do the measurement and ensure you are measuring the pin on P9A you think you are.  It is easy to measure adjacent pins in error
    • Remeasure CREG1.  That should not be 0V
  • We are using Rev. B eval schematic. All tests are being carried out using the same.
    Is it required to switch to Rev. D version ?
    We have measured multiple times so I believe pin error may not have happened.
    CREG1 is measured as 0V only.
    Any ideas would be highly appreciated.
  • If the ADAR1000 is working, it is not required to switch to the Rev. D.  I still do measurements on Rev. B boards.
    The CREG1 being 0V could effect the PA Bias.  See Figure 86 in the datasheet.    You may have a damaged ADAR1000.
    You may want to purchase the latest evaluation board.
Reply
Children
No Data
