Hi we are willing to create our own on board based on the tinyrad design
1. Can you please send me the schematics and layout of the hardware?
2. Can you send us the firmware to be used on the DSP?
3. Our goal is to detect objects with RCS as low as -20dbsm, hundreds of meters.
A. Can we double the amount of receivers and transmitters? (I.e. put four transmitters and 8 receivers in our board) How can we sync between the multiple chips? Is there any user guide?
B. We would like to use power amplifiers in order to increase the transmit power. Can you suggest any models of amplifier chips?
C. Is it possible to use higher frame times? What are the memory limitations in the DSP?
D. Can we do modifications in the PC evaluation software in order to support all of the above?
Thanks !
