HMC601
Last Time Buy
The HMC601LP4(E) Logarithmic Detector/Controller converts RF signals at its input, to a proportional DC voltage at its output. The HMC601LP4(E) employ...
Datasheet
HMC601 on Analog.com
Hi Experts ,
Good day ,
Please refer to below image of bottom unit and looks like discoloration occurs ?
Can you please advise the acceptance level and can I proceed with solder test for the acceptance ? Need your recommedation for this issue.
If baking required pls advise the baking condition .
Looking forward for your support.
Regards
Manoj Balakrishnan.
Hi ADI team ,
Can i get the reply on this technical issue ?
Pls advise and looking forward for your support.
Thank you
Regards
Manoj Balakrishnan.
Hi ADI team ,
Can i get the technical answer for this issue ?
Waiting for long time .
Pls advise..
Hooman Pls advise on this query .
Hi Manoj,
I'm forwarding to the Application / reliability engineer responsible. Hopefully, they'd be able to respond to you soon.
Hooman
Hi Manoj,
I've received the following response from the responsible engineer regarding your query:
"Please refer to the below material declarations form that confirms that for model HMC601LP4ETR MSL Rating is 1.
https://quality.analog.com/searchresults.aspx
So according to the question, The MSL rating of the 24 Lead QFN package is MSL 1."
Hooman
Thank you so much Hooman
