Is it possible to use a 10 MHz external PLL reference frequency for the ADMV4420? The datasheet shows 50 MHz typical but does not show a minimum or maximum. Same question for the ADMV4540.
Thank You.
ADMV4420
Recommended for New Designs
The ADMV4420 is a highly integrated, double balanced, active mixer with an integrated fractional-N synthesizer, ideally suited for next generation K band...
Datasheet
ADMV4420 on Analog.com
ADMV4540
The ADMV4540 is a highly integrated quadrature demodulator with integrated synthesizer ideally suited for next generation K band satellite communication...
Datasheet
ADMV4540 on Analog.com
Thank You.
Yes, 10MHz external reference is possible. You will need to verify phase noise performance meets requirements and/or modify loop filter/charge pump current.
Great, thank you.
