The datasheet for the HMC980LP4E bias controller gives VDD and VDrain as a minimum of 5 volts. Also, the configuration spreadsheet won't let me enter a VDRAIN voltage of less than 5 volts.
Why is this?
I want to use the HMC980 with the HMC943APM5E power amp, running the HMC943 drain at 4.5 volts. The datasheet for the HMC943APM5E gives data curves down to a supply voltage of 4 volts.
Does this mean I cannot use the HMC980 to provide a drain voltage of 4.5 volts to the HMC943?
Thank you.
Edited title to give part number.
[edited by: Mike556 at 10:54 PM (GMT -4) on 12 Apr 2024]
