Hello.
I would like DXFviewer data for EVAL-ADMV1530 and EVAL-ADF41513.
Can you provide data about EVAL-ADMV1530 and EVAL-ADF41513?
best regards.
Strong EMC design
ADMV1530
Recommended for New Designs
The ADMV1530 is a general-purpose, double balanced mixer in a
leadless, RoHS compliant, surface-mount technology (SMT) package
that can be used as an upconverter...
Datasheet
ADMV1530 on Analog.com
ADF41513
The ADF41513 is an ultralow noise frequency synthesizer that can be used to implement local oscillators (LOs) as high as 26.5 GHz in the upconversion and...
Datasheet
ADF41513 on Analog.com
Hello.
best regards.
Hi baggio,
All the information you require can be found in the design resources section of the links I have pasted below:
ADF41513: https://www.analog.com/en/resources/evaluation-hardware-and-software/evaluation-boards-kits/eval-adf41513.html#eb-gettingstarted
ADMV1530: https://www.analog.com/en/products/ADMV1530.html
You can also find the datasheet for each product. Let us know if you require more information.
Regards.
Hi JudeOsems-san.
Thank you for information. But excuse me, I know this information.
I want is "DXF data" that describes the dimensions of EVAL-ADF41513 and EVAL-ADMV1530.
If I don't have the DXF data, can I get the PDF data?
Best regards.
Hi baggio,
I have attached the PFD file for ADF41513 information and the DXF file for ADMV1530. As I have mentioned earlier, these can be generated using the design resources found in the link I sent above.
Regards
Hi JudeOsems-san.
Thnak you. Regarding EVAL-ADF41513, I understood that the only option is to convert the "art data".
However, isn't the device data attached for ADMV1530?
What I want is DXF or PDF data of EVAL-ADMV1530.
This is not individual data for ADMV1530.
best regards.
PDF
Hi baggio,
I have attached the ADMV153 PDF data as well. I hope this helps now.
Regards
