HI
i need to generate 10 GHZ using the HMC734 VCO but by looking in the data sheet the interface of the pins in the pins interface is different from that in the application section
i don't know any interface i should flow
Strong EMC design
HMC734
Recommended for New Designs
The HMC734 is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC734 integrates a resonator, negative resistance device, varactor diode...
Datasheet
HMC734 on Analog.com
HI
The interface schematic shows the internal (IC) schematic for each pin.
You should follow the application circuit. If you need 10GHz RFout, then apply ~8.5 V Vtune level, instead of 5V (referencing to application circuit)
Michelle
