| SLA Status | Assignee | Support Status |
| SLA Closed. | MStokowski JudeOsems PeterW kieranb |
Open |
ADF4382A
Recommended for New Designs
The ADF4382A is a high performance, ultralow jitter, fractional-N phased-locked loop (PLL) with an integrated voltage controlled oscillator (VCO) ideally...
Datasheet
ADF4382A on Analog.com
I used ADISimPLL on the new ADF4382A MMIC.
In the simulation was able to use a FREF=5MHz with divider R=10 to get Fdet = 500 kHz.
However, in the data-sheet I see FREF(min)=10 MHz and Fdet(min)=5.4 MHz.
Can you confirm that there is a problem with the ADISimPLL model of the ADF4382A ? Or am I not reading the data-sheet correctly?
Thank you for your support and feedback!
stephenv - Moved from Other Products (EN) to RF & Microwave. Post date updated from Tuesday, March 19, 2024 11:50 AM UTC to Tuesday, February 3, 2026 9:08 PM UTC to reflect the move.
stephenv - Moved from Other Products (EN) to RF & Microwave. Post date updated from Tuesday, February 3, 2026 9:08 PM UTC to Tuesday, February 3, 2026 9:08 PM UTC to reflect the move.
The datasheet is correct. The model in SimPLL will need to be changed to reflect this. Thanks for bringing this to our attention.
Kieran
