spurs when using divided by 32 adf4356
Product Number: ADF4356
i see large spurs when i use output divider /32 or /64 in adf4356.
VCOout is 3840MHz witch divide by 32 will be 120MHz.
f_Refin = 100MHz , R = 1, PFD_Freq = 100MHz.
   Looking forward to your reply.
   Best regards.
Parents
  • Hi Mahdi,
     In the datasheet, figure 11 demonstrates what is the expected harmonics level, you can compare your results with the datasheet values and my measurements. I am also sharing my register settings. you can see harmonics but spurs should be minimal and just around the carrier frequency with a narrow bandwith.  you should check if the bleed current is enabled for the Fractional-N mode.
    Burhan
Reply
  • Hi Mahdi,
    Burhan
Children
No Data
