LT5581_Power Mesurement
The user encountered a flat output voltage (1.4V) when measuring RF signals at 5.8GHz with input power from 5dBm to 10dBm using the LT5581. The final solution recommended placing a 20dB RF attenuator at the input to bring the signal into the detector's optimal range of -15dBm to -10dBm.
View FAQ
Product Number: LT5581
good morning  ,
i've tried to mesure an RF signal at 5.8GHz with an input power from 0dbm to 10dbm but the problem is that the output voltage for the range of power 5dbm to 10dbm was the same (Vout=1.4V).
the input power as a maximum rating  for the LT5581 is 15dBm (mentioned in the datasheet) .
how can i solve this problem please .
