Dear All,
I am designing Local oscillator by the ADF4351.
Regarding the LD Pin, I would like to know the LD pin's drive power.
I woul like to drive LED by the LD pin.
Could you please inform me.
Harunobu
ADF4351
Recommended for New Designs
The ADF4351 allows implementation of fractional-N or integer-N
phase-locked loop (PLL) frequency synthesizers when used with
an external loop filter and...
Datasheet
ADF4351 on Analog.com
Dear All,
Harunobu
Hi Harunobu,
Muxout can drive a LED but LD outputs current capacity is around 500uA. It is difficult to drive a regular LED directly with this output. You can use MUXOUT or you can add a opamp at the output the LD pin to drive a LED.
Burhan
Hi Harunobu,
Burhan
