Hi! The marking on the component differs from the information in the datasheet. Is it a fake or an old component without ROHS
Strong EMC design
HMC642
Obsolete
The HMC642 is a 6-bit digital phase shifter die that is rated from 9 GHz to 12.5 GHz, providing 360 degrees of phase coverage, with an LSB of 5.625 degrees...
Datasheet
HMC642 on Analog.com
The XXXX indicator in the datasheet is saying that there will be a 4-digit/letter code under the H462A that respresents the lot number for that part. They write it as XXXX because that number will change over time, that is, from lot to lot. So this is not an indicator of a fake part.
Dear Enash, thank you for the answer!
I'm sorry, my question was incorrect. The question is about the presence of a horizontal line under the digital code. in the documentation for other AD products, there is a distinction between marking with a horizontal line for components corresponding to ROHS and without this line.
For example
In our case, the line is present in the drawing in the documentation, but remains on the component package
I think that you need to take this up with the authroized distributor that you purchased this part from.
